Blown Engine....Thinking about a Swap
Old Jul 20, 2005 | 11:44 PM
Alchemist's Avatar
Basically, I was going to say that with the piggy you were probably OK using 93. It's more than you need, but it's your money
I'd just rebuild to make another G94 better. Pistons, cams, headwork, valve springs... go after the IM while everything's off the car. Just go wild. The G69 swap is going to be tricky, but you already know that. and if you're concerned about expense, that makes the G69 swap a no-no.
Don't buy new rods because the stockers are good to at least 9 PSI. Unless you're doing your research to figure out whether you want longer or shorter- but don't buy new rods for the sake of new rods.
As long as everything's off, you might as well do the tranny stuff, too. Flywheel (ehh... I'm not sold on these except for drag racing), clutch (for sure!), LSD?! Why not
But if cash is an issue, start simple and at least get the car running.
Good luck
Old Jul 21, 2005 | 09:31 AM
livelyjay's Avatar
Originally Posted by GreenPsycho
yeah, screw that, pick up the 4g94 for 440 and the 1 yr. warranty. assuming your or your buddies (jotun, fox, etc) are doing the swap, spend the extra dough on some pistons or something
So I guess I don't get to help ... oh, I guess I count as "etc".
Get the 4G94 with the warranty, pistons, rods, LSD (don't buy it from RRM, search up on the Mirage forums as I'm sure someone there knows the part number), and clutch.
Old Jul 21, 2005 | 10:15 AM
N1te's Avatar
you're welcome to help... i can use all of it that i can get. we're doing it this weekend though i think ull be up in CT right? all of this work at the military garage on fort belvoir.
UPDAte on ride: I ordered 10.1 Pistons through Buscher Racing... I'll get them tommorrow and have them pressed onto Stock Rods.
Old Jul 21, 2005 | 10:31 AM
GreenPsycho's Avatar
dam this weekend? so soon?
don't mean to speak on behalf of other people, but i think jason's coming up next weekend to hook tyler up
Old Jul 21, 2005 | 10:40 AM
N1te's Avatar
yeah i'm on this like a fat kid on a cupcake. i want my car
Old Jul 21, 2005 | 10:41 AM
Shingen's Avatar
Man... I hope I can get all my work done so I can come help out!
Fox
Old Jul 22, 2005 | 10:37 AM
N1te's Avatar
this is going to be a buuuusy weekend... I'm hopin I'll be one of the fastest n/a lancers.. at least in the va area
Old Jul 22, 2005 | 11:12 AM
silkymp's Avatar
what kind of NA mods are you going to be doing?
Old Jul 22, 2005 | 10:39 PM
Shingen's Avatar
Hey Frank I want to help tomorrow call me so I know if you need a ride bro.
Fox
Old Jul 23, 2005 | 07:33 AM
livelyjay's Avatar
Not likely without a lot more mods. Have a fun weekend with the swap. I'll be having fun on my mini vacation up here in NY. I also had a lot of fun ripping around traffic following an S4, till a cop decided to pull me over
Old Jul 23, 2005 | 11:48 PM
N1te's Avatar
I'm going to be running 10.0:1 Weiseco pistons. Does anybod know if this would run fine with RRM's piggyback and can these run on the stock rods?
Old Jul 24, 2005 | 05:50 AM
gregivq's Avatar
Stock rods will do but you will need to get your pistons pressed down to your stock rods at a machine shop.
And with Wiseco pistons and RRM's piggyback you might be a little bit lean in top end but not likely.
Old Jul 24, 2005 | 08:09 PM
Jotun's Avatar
We have a press so no need to take them to a shop and I think you will be fine with the piggy back even though I dont like it. I would suggest going to another more tunable piggyback if you want to be the fastest NA lancer.
Old Jul 25, 2005 | 09:33 AM
N1te's Avatar
well faster than you at least
Old Jul 25, 2005 | 08:34 PM
Jotun's Avatar
lol aight we'll see how much your pistons help!! Nahh just joking your going to be really quick but we should think about polyurethane mounts and a 93 mani while we are into it this deep. Maybe even a clutch and flywheel combo as well.... Oh yeah call me tommorrow I need something out of your car before I get pulled over AGAIN...
