might be a stupid question.
Old Jul 20, 2005 | 04:59 PM
jaybo1977's Avatar
Unhappy might be a stupid question.
Is it just me or id=s it a pain in the a** to get the screws for the air mass sensor out. I tried with a regular socket and th eplastic on the inside broke and now the damn thing just turns and i'm having trouble holding to release the nut. Any suggestions out there?
Old Jul 20, 2005 | 05:05 PM
nutrulz's Avatar
Sorry I don't have anything better to tell you than, grab your ankles.
Old Jul 20, 2005 | 07:12 PM
SLVROZ_03's Avatar
Pliers on the inside piece that turns, and the socket wrench on the outside worked for me.
Old Jul 20, 2005 | 07:16 PM
jaybo1977's Avatar
So did you have the same problem? And it seems i can't get a very good grip on the inside with any pliers
Old Jul 20, 2005 | 07:46 PM
twardnw's Avatar
well, I got mine off just fine, you just have to hit your ratchet really quick with a hammer, or use an impact gun (on a low setting) to bust the nuts (rofl) free w/o cracking the plastic. Go grab a set of vise-grips if regular pliers aren't holding on tight enough now tho
Old Jul 20, 2005 | 09:51 PM
Punz0247's Avatar
ratchet and wrench did we wonders.......have fun
Old Jul 21, 2005 | 02:22 AM
Slovak's Avatar
Sweet avatar man!
Old Jul 21, 2005 | 09:57 AM
Proffesional's Avatar
yea same here ig ot my intake injen on and then the screws wernt comin out so my friend hit it with a hammer and the sensor broke and i had to get a new sensor for 139$$
Old Jul 21, 2005 | 11:03 AM
oz4g94's Avatar
did you wait for the engine to cool down before taking it apart? i had no such problem with mine when putting on my cai.
Old Jul 21, 2005 | 12:05 PM
twisty1251's Avatar
i had the same problem. its a PITA! use a socket or impact gun
Old Jul 21, 2005 | 01:43 PM
DemisedGabe's Avatar
yah that same **** happened to me man, where the things broke , all i did was use pliers and soocket wrench
Old Jul 21, 2005 | 04:59 PM
Alchemist's Avatar
I just had to replace my MAS and the replacement came with half the Mirage airbox attached because the jackholes at the yard stripped the insides. To be fair, they were on TIGHT! I ended up drilling them out and reusing my bolts from the first MAS. All you'd need to do is get yourself to a hardware store... oops, that's how old I am, a HOME STORE and go to their fasteners section. Shouldn't be too hard to find replacements. Fill the holes around the bolts with RTV to ensure proper seal
Old Jul 21, 2005 | 06:20 PM
Xshieldsx's Avatar
Yeah mine cracked all to hell and I just sat there in shock for about 3 minutes with my mouth open and then just ****ing threw it. But I then went at it with vise grips and a socket wrench (10 mm).
But ****ed up the honeycomb mesh shlt on the inside and had to sit and push it all back out with a dinky *** piece of wire. Sucked.
Good luck.
Old Jul 21, 2005 | 07:40 PM
jaybo1977's Avatar
i'm so glad that i'm not the only one that felt that way. Those damn things are driving me crazy. Still don't have them out i got too frustrated and gave up.
Old Jul 21, 2005 | 08:22 PM
Evo666's Avatar
i used vise grips and a friends help
