93 Mirage Engine parts
Old Jul 27, 2005 | 11:10 AM
jsfour's Avatar
Are there any parts i can use for it? I know i can run the intake manifold. What about the block?
Old Jul 27, 2005 | 11:48 AM
livelyjay's Avatar
Nope. Block will be much smaller. I think the 93s ran a 1.5L and 1.6L, but I am probably wrong. Various sensors and such may be the same, but I doubt the intake manifold and the head are the same.
Old Jul 27, 2005 | 11:50 AM
HobieKopek's Avatar
Can you even use the '93 Mirage IM? If it's not a 1.8l I'm gonna say no, and if it's not oriented the same way, I'm gonna say no again. I could be wrong, but I don't think you're gonna get anything you'd actually want to use. 97+ are very similar, but prior...I doubt it.
Old Jul 27, 2005 | 12:11 PM
03RallyLancer's Avatar
do you mean 1993 or 4g93? giving us the engine code would be a lot more help then just a 2 digit number
Old Jul 27, 2005 | 01:26 PM
jsfour's Avatar
haha yah i mean the 4g93 i probably shoulda put more than just a fiew letters in there
Old Jul 27, 2005 | 06:16 PM
HobieKopek's Avatar
Oh. In that case... The head is the same, the valvetrain I believe is the same, the cam is different, the cam position sensor is different, the cam gear is the same. That's all I can think of ATM.
Old Jul 27, 2005 | 08:53 PM
lancermarin's Avatar
Weren't the valves from the 4G93 solid, while ours are.. what, hydrolic?
Old Jul 27, 2005 | 10:03 PM
i think 97 are solid and then 98+ are hydro or something like that. I pm dave(mitsiman) about this and he told me that the lifters might be solid depending on the year... when a mirage guy drops in he will know for sure.
andrew dont forget about the exhaust manifold and im. exhuast manifold will be a lil short though.
Old Jul 27, 2005 | 10:12 PM
AznFlip's Avatar
is there any 4g93 Lancer/Mirage with Mivec? I know there isn't here in U.S, probably in other countries? or none at all?
Old Jul 27, 2005 | 10:16 PM
i dont recall if there is a mivec... but i think i remember seeing a dohc turbo 93
Old Jul 28, 2005 | 12:25 AM
AznFlip's Avatar
I assumed this question have been answered here before, but since we're talking about '4g93 parts, does the '93 piston/rods will fit '94 block?
Old Jul 28, 2005 | 03:49 AM
HobieKopek's Avatar
I didn't forget about the exhaust manifold or the throttle body, but I don't see any benefit to swapping out for those so I didn't mention them.
No. Different bore and stroke.
Old Jul 28, 2005 | 10:08 AM
Blacksheepdj's Avatar
Exhaust manifold would be better. It's a tubular header (yes, stock).
TB is much smaller, as far as I can tell.
Old Jul 28, 2005 | 11:53 AM
Alchemist's Avatar
tbs are 50mm and have different wiring harnesses for everything (TPS, etc.)
Obviously the IM works the head would probably swap, but it would be a stock replacement if it did, same thing for the cam gear. I believe they are solid lift adjusters vs. our hydraulic (IIRC a conversation with AirQuez) and they may have a method of adjusting them that ours wouldn't (because they're supposed to be self adjusting).
That's all I can think of right now.
Old Jul 29, 2005 | 11:08 AM
KillahB's Avatar
Hybrids, yes there are. Stock, no they are not. However, the 4G92 MIVEC intake manifold fits and works great.
