cam gears
Old Aug 4, 2005 | 06:49 PM
utiheadbanger's Avatar
Hey, anytime I can help a fellow Lancer fan is a good one. I have been in school since August and have learned more than I ever imagined...including about performance and various false pretenses people believe.
Old Aug 4, 2005 | 06:51 PM
gregivq's Avatar
give me more, moreeee
thx for the info
Old Aug 4, 2005 | 06:53 PM
What else do you want to know? I have an entire book on this stuff on top of the crapload I have learned in school thus far. 5 more classes left until I work at BMW full-time!
HobieKopek's Avatar
RPW has cam gears as well. If you can find anyone who makes a Mirage cam gear it'd work too. I can't stress enough just how identical our cam gears our from the 1.8l Mirages.
Old Aug 4, 2005 | 06:54 PM
Yeah it is funny...that and our '02-'03 Lancer was in Japan in '01 as the EVO VII...that and we replaced the Mirage over here...are you sure the valve overlap is the same? I don't know much about that car...enlighten me maybe?
Old Aug 4, 2005 | 06:56 PM
gregivq's Avatar
What would I need to know with higher comp. ???
datdjrobp's Avatar
i've farted around enough with this car doing the basic stuff, it's time to decide whether or not i want to play with it for real or just make it look pretty. not having a 2nd car or a garage are real deterants at the moment.
intake and exhaust, those were pretty to get instant gratification from. test pipe...eh. according to el upgrade path from rrm, i should be getting a bored throttle body, but my mind keeps telling me the piggyback sounds more interesting.
Old Aug 4, 2005 | 06:58 PM
Depends...if you go higher compression keep your car naturally aspirated (not forced induction). If you go turbo or super, you want lower compression because the turbo/super acts as a sort of "fake" compression. Say you have 8.5:1 compression and a 10 psi boost turbo...now I don't know the exact math but it would equal around the compression of say 10:1...so high compression + turbo = detonation.
Good when you do heavy tuning...it's like reflashing an ECU but it allows you to go back to stock if you decide to change anything and not like it...if you go with the bored throttle body and the matching intake (called port-matching) it will make a big difference.
Old Aug 4, 2005 | 07:02 PM
gregivq's Avatar
yeah but high compression and timing how is it related?
Old Aug 4, 2005 | 07:05 PM
They are and aren't...
Your compression is how much your piston can compress your air/fuel mixture for burning...it is step #2 in the 4 stroke cycle... Intake, compression, power, exhaust. You need the cam to take care of #'s 1 and 4, and compression takes care of...you guessed it, #2. If you have too much of a mixture to compress and your timing is too advanced...your piston will hit the valves, or you may explode the mixture too soon, this is called detonation.
Old Aug 4, 2005 | 09:44 PM
Blacksheepdj's Avatar
I knew I forgot one company... *smacks forehead*
Old Aug 16, 2005 | 02:37 PM
Lil red '03's Avatar
Thank god for the almighty search feature
You serious Hobie ? I hope you are - i'm been kicking around the idea of getting a cam and I saw Fidanza made a cam gear for the 1.8 L. I wasn't too keen on getting an RPW cam gear for lack of the timing marks. I am still kicking around that idea or just getting in on that RIPP group buy
Old Aug 16, 2005 | 02:40 PM
HobieKopek's Avatar
How many times must I say they're identical before people take me seriously? Yes, they're the same. I have both. They're the same part #'s, same parts. More identical than Mary Kate and Ashley.
Old Aug 16, 2005 | 02:43 PM
Good enuff for me Hobie
Relax and have a on me
Thanks
Old Aug 16, 2005 | 02:52 PM
uranium9v's Avatar
I have the RPW cam gear. Had to "degree" it myself. I really swear by these things. If you upgrade your shaft, get a gear too. Advancing the timing Mechanically has been so much more reliable then messing with emanage/ecu flash. I now use an AFC along with.
