Engine And Tranny Swap
Old Aug 5, 2005 | 12:44 AM
fl.lancer02's Avatar
I Read All That On The 25 Page Thread The 4g63 Engine Is Rather Cheap 800$ 180 Hp Is Nice But If I Could Fit The H22 And Maybe Swap Ecu's 220 Hp Sounds Nice.i Got A Friend Going To School For Stuff Like This He Says They Have A Program You Put In Your Car And It Goes By Engine Bay Size On What Swaps You Can Do.he Has A Cavalier And For His A Gto,911,and Something Else Came Up.
Old Aug 5, 2005 | 12:48 AM
what about are ignition set up can we use the msd 6a box i think thats the numbers.
Old Aug 5, 2005 | 12:50 AM
erockOZ's Avatar
From: Northwest Chicago Subs - Serving in Korea till 09
I don't argue that the engine wouldn't fit in there, it's more of the fact of mating the engine and trany and mounting the engine. It would not be anything close to a simple civic or prelude swap. If you are willing to make your grand am your daily driver and have alot of faith in your friend; I say, save up and see what you can do. I wouldn't do it personaly, but by no means does that mean you should not try if you feel that strongly about putting a H22 in your lancer. It would sure be an interesting thing to see it work properly.
Old Aug 5, 2005 | 12:51 AM
so you would almost be certain the engine would fit. couldnt i just swap tranny too.
Old Aug 5, 2005 | 12:52 AM
erockOZ's Avatar
use the ignition box on the hypothetical h22 lancer or on the current 4g94 lancer?
Old Aug 5, 2005 | 12:54 AM
the ignition was for the 4g94 i have the magnecore plugs off of rrm.but the lancer has that wierd set up i dont think it has a distributor right. atleast a regular one
Old Aug 5, 2005 | 12:56 AM
erockOZ's Avatar
I'm not saying that the engine would fit for sure, can't say i've ever looked into it. But if you buddy can check that out for you, I would beleive what he says. A tranny swap could help you out there, but that is beyond my realm of knowlege. I don't know how much would have to be custom work and how much could just be swapped out. But by the time you swap engine and tranny into a lancer, I would ask myself... why not just either drop 8-10g's and make a 300whp lancer or get a more powerful car.
I think you could get the parts for your swap pretty cheap but the labor will end up hitting you hard if I'm right about making everything line up right.
Old Aug 5, 2005 | 12:59 AM
erockOZ's Avatar
From what I know, those boxes are well known for frying out the evos. Also, from a few of the set ups i have seen and ridden in, there is no real need for that. With the dual coil packs, the lance seem to put out very good spark to begin with. From what I have seen, you should be able to make an easy 250whp lancer on stock ignition packs. You will need better plugs and wires (that you have already) but I think the packs are fine for controlling them.
Old Aug 5, 2005 | 01:00 AM
my lancer is almost paid off and i already have custom exhaust k&n intake kamikaze headers magenacore plugs road races piggy back ecu. ive put at least 2500 and really not to happy with results
Old Aug 5, 2005 | 01:03 AM
my friend has a honda hatch with the b16 jdm swap and he spanks my *** and he tells me how he beats 5.0 mustangs and cameros going from 95 hp to almost 200 hp for only 3500 is a good and safe way to upgrade quickly
Old Aug 5, 2005 | 01:06 AM
erockOZ's Avatar
I know where you are coming from. Thats the reason I sold my lancer for a different platform to work with. untill you turbo a lancer, the results from modding are not that noticeable. There are alot of possibilities out there, be it swaps, upgrades or new car; just keep searching around and see what will make you happy. Remember, you could do your swap and still be unhappy in the power you end up with. That is not a sure thing to make you happy with it for the cost.
I need to sleep some tonight, but feel free to pm me with any more questions or ideas and I would be more than happy to lend some advice or help where I can. I will also try to follow this thread for a bit.
Good Luck
-Eric
Old Aug 5, 2005 | 02:54 AM
Jotun's Avatar
this thread is ridiculous. It simply sounds like you hate your car and are to broke to go buy a Honda that you so endearingly love. And you are hopeing that it would be cheaper to swap a Honda engine into your Lancer. Well I say go for it but I hope you like walking.
Listen to Alchemist he knows his ****.
Old Aug 5, 2005 | 08:11 AM
N1te's Avatar
Put a Aston Martin DB9 engine in it. It bolts right up without any modifications to the body. It's a 450-hp V12... talk about power! There's a lancer down on fort belvoir with a silver evo wing that has one.... Man that thing flies!
Old Aug 5, 2005 | 09:51 AM
wiretap's Avatar
You Can Put An Evo Engine Into The Lancer. It Has Been Done Successfully. Just Take A Look. And Can You Please Stop Typing Like This. Thanks.
:::::SPECS:::::
LENGTH: 4360 mm
WIDTH: 1770 mm
WHEELBASE: 2600 mm
TRACK: (front and rear) 1550 mm
WEIGHT: 1230 kg
ENGINE: 4G63, 4 cylinder, 16 valves DOHC turbocharged
BORE x STROKE: 85.5 x 86.9 mm
DISPLACEMENT: 1996 cc
ENGINE MANAGEMENT SYSTEM: Magneti Marelli, multi injection
MAXIMUM OUTPUT: 220kW @ 5500 rpm
MAXIMUM TORQUE: 550Nm @ 3500 rpm
CLUTCH: Carbon triple plate
TRANSMISSION: Ricardo/MMSP 4 wheel drive, 5 speed, limited slip differentials front centre and rear
MAX. SPEED: 220km/h
SUSPENSION: Front and Rear McPherson strut, coil springs, anti roll bars
STEERING: Power assisted rack and pinion
BRAKES: Brembo, ventilated disks: 370 mm diameter tarmac, 300 mm gravel, 328 mm snow, 8 pot calliper tarmac, 4 pot gravel and snow
WHEELS: Enkei magnesium cast 8x18 tarmac, 7x15 gravel, 5.5x16 snow
TIRES: Michelin
FUEL TANK: 90 litres
SEATS: Recaro composite
COCKPIT: Components Seabelt
INTERCOM SYSTEM & HELMETS: Stilo
CAR DESIGN: Using PTC Pro Engineer
Old Aug 5, 2005 | 10:19 AM
Danno's Avatar
First off.
Bwahahahahahhahahahahahahhahahahahahhahahahahahhah a'
Secondly.
This is a joke right? Your just kidding around? If you really want a car with a H22 then buy a 89 civic (lightest civic ever made) and drop it in that for under 2K. You will have a fast car.
I will leave EvoM if this is even attempted.
