4g63 Head on the Lancer OZ??
Old Aug 31, 2005 | 09:21 PM
OkiDvlDog's Avatar
good stuff, 2.0 litre mivec turbo doesnt sound bad at all , o man, decisions decisions, thnx again fellas
Old Sep 1, 2005 | 07:07 AM
firebolt's Avatar
that would be pretty sweet. a mivec turbo.
Old Sep 1, 2005 | 07:34 AM
gregivq's Avatar
Originally Posted by jdjd831
Seriously, for about thirty dollars and some time researching techniques you could port it yourself. Seth and I ported his head ourselves before we swapped motors and his motor is pulling strongest right before he hits the rev limiter. For those of you who don't know, Seth and I swapped a 4G94 into his 1.5L mirage. You also want to open the intake runners up to match the ports in the head when you're done with them. Add a header and full exhaust plus an ECU reflash and it will make a very noticeable improvement in performance. If you wanted to you could even do the stock cam that's in the 4G93, it has a 248/248 duration instead of 240/248 that the 4G94 comes with. Or if you really want to get crazy with it then do the 4G92 MIVEC head swap that has been ported add a decompression gasket and a turbo and you have a 2.0L MIVEC Turbo lancer. Can you say EVO Jr? Any way you go though you can get a decent amount of extra power out of the motor without putting a major dent in your pocketbook.
so much INFO!!!
But a little bit confused??? Did you guys put 4g94 engine (block, head) into your mirage or just the head? Also is it really possible to swap 4g92? into 4g94? And once again only head or the whole block with the head? And what year a model of mitsu is it?
Old Sep 1, 2005 | 07:39 AM
firebolt's Avatar
ive seen hybrids of 4g93s and4g92s. hopefully the mivec head will go on the 94.
Old Sep 1, 2005 | 11:28 AM
jdjd831's Avatar
We swapped a 4G94 complete OZ motor and ECU into his 99 mirage DE. His Mirage was a 4G15 which is not the same block or head type as the 4G9x series. It is however the same bolt pattern for the tranny and the dimensions are similar. Any 4G9x series head will fit the 4G94. The 4G92 MIVEC head swap onto a 4G94 is what you would want to do. You gain the displacement of the Lancer motor with the cylinder head breathing characterisitcs of the 1.6L MIVEC motor.
Old Sep 1, 2005 | 11:30 AM
grubiaco's Avatar
mivec turbo, yum!
Old Sep 1, 2005 | 04:55 PM
gregivq's Avatar
Sounds good but does that also mean EMS?
Old Sep 1, 2005 | 05:47 PM
firebolt's Avatar
from what i read u only need the ecu from the mivec engine.
Old Sep 1, 2005 | 07:00 PM
gregivq's Avatar
That's like a totally new level for US Lancers. We got high compression, we got turbo, sds, and now mivec swap. Just need more info where to get the motor and what would be needed.
Old Sep 1, 2005 | 07:14 PM
astondg's Avatar
Wouldn't the fueling be all wrong with the extra displacement and power output?
Old Sep 1, 2005 | 08:12 PM
jdjd831's Avatar
An ecu reflash or a standalone would be the preferred method of fixing the fuel delivery problem. A piggyback would work also if you had to.
Old Sep 2, 2005 | 01:36 AM
astondg's Avatar
I think a good standalone would be the best way. Then you get the fueling sorted, maximum performance benefits, and the good ones will let you control the MIVEC system too. It might be hard to get a reflash for the ECU from the MIVEC engine since I don't think it was sold in the US?
Aston
Old Sep 2, 2005 | 06:00 AM
gregivq's Avatar
Any info about a year and model of the car with that engine? And maybe prices of the head?
Old Sep 2, 2005 | 07:53 AM
KillahB's Avatar
As a Mirager who has searched for this for many years, finding one is like finding the Holy Grail. Very popular in Ireland in their later model Mirages, Cyborg ZRs, Proton Satrias etc etc, and common in Malaysia and Taiwan (sometime labelled a Virage). You can also find some of them in the Caribbean islands (attached is a pic from one car back home). But to find one and get it over here will be tough.
Old Sep 2, 2005 | 09:13 AM
gregivq's Avatar
So it's in Europe. I will look into that.
