maybe valve problems???
Old Sep 4, 2005 | 02:45 PM
DickMorgan's Avatar
ok i'm usually not good ..decyphering sounds that my engine makes but i noticed... when i'm like in the lower rpm's and i accelerate at a medium to high pace...i hear like some ..not tapping noises..but sounds like tapping noises.i THINK it's my valves working...i'm not sure....kinda sounds like valves but they're loud...i can hear it over my radio at medium volume..and wondering if something is going wrong with my valves or is it normal????? my car still runs good..actually below 3,000 rpms...the engine stutters just a little bit but once it starts at the powerband it's all gravy... is something going bad on my car..it only has 18000 miles on it.. i'm curious
Old Sep 4, 2005 | 02:47 PM
vikktorlv's Avatar
noises
Have you checked the oil? Maybe you are low on oil, try using a different gas next fill u p too. Might not be anything serious.
Old Sep 4, 2005 | 02:50 PM
DickMorgan's Avatar
no i did an oil change about 1,000 miles ago.. with really good oil..everything is good..always us chevron 87 octane..nothing else..casue i dont wanna change brands of gas...should i try going to another gas station and see if i have same thing happening???
Old Sep 4, 2005 | 02:53 PM
vikktorlv's Avatar
you always go to the same station? try a different station same brand?? maybe they had a bad batch, check the oil anyway. sometimes maybe it didn't get filled all the way or some is gone.
Old Sep 4, 2005 | 02:56 PM
DickMorgan's Avatar
what if i try another brand like shell???? i heard shell is good gas. and yes i do usually go to the same station down the street from my house everytime i fill up my car with is like every 6 days or so
Old Sep 5, 2005 | 08:56 AM
comatose721's Avatar
how bad is the studdering? can you explain it in more detail...get some injector cleaner, new oil, and a tank of gas from a differet distributer and see if that helps...also check your plugs,wires, and coil packs for obvious wear and tear....insufficent spark could cause problems.
Old Sep 5, 2005 | 08:21 PM
SLVROZ_03's Avatar
Try Exxon or Shell, like mentioned above.
Old Sep 5, 2005 | 08:32 PM
alexis525's Avatar
it could possible be a recall... i know there was on my year lancer.. .not sure if it included the 04
Old Sep 5, 2005 | 08:40 PM
gregivq's Avatar
Check your plugs, maybe you are misfiring. Check the gap, the white, bottom portion of the plug, and see if there are any marks on the plugs.
Best, just post pics of each one of the four plugs.
Old Sep 9, 2005 | 05:35 AM
i've been trying to fix my misfire for about a month now! i has a lean misfire that only happened in powerband and i found out the o-ring on the high pressure fuel line was blowing fuel out into a puddle at the base of my IM. then i changed my plugs (which had 2k miles on them and they burnt completely out) and wires...now i have corrected the high end misfire and the car studders and misfires between 1300-2800rpm's!!! i believe my coil pack went bad now too. i pulled it out and it was coated in a nasty, brown, powdery substance..... i'm trying get off of this road to recovery and get back to the track and run some numbers.
Old Sep 9, 2005 | 06:26 AM
gregivq's Avatar
Wow, sounds much worst than what my car was doing. Anything over 3.5k rpm and it would misfire like crazy, causing lean condition.
I bought new wires, new plugs, new boots that connect the coils to the plugs, and it worked.
Old Sep 9, 2005 | 10:07 AM
Alchemist's Avatar
Dick- that's the lifters at work. Nothing you can do about it and I think it was the first thread discussed when EvoM went online Actually, you CAN take apart your head, bleed the lift adjusters, reinstall them and see if they'll fill with oil a little more evenly. OR you can get the lifters with solid "adjusters" from a G93 engine- they won't click. Eitehr option is going to cost at least a grand to fix something that's not broken. Otherwise don't worry about it
Old Sep 9, 2005 | 11:24 AM
gregivq's Avatar
Alchemist is right. Hmmmm 4G93 solid lifters in our head ....... never thought of that.
As far as I remember each lifter/valve lash adjuster is about $10 and you got 16 of them and some work to it.
Use some Valve Medic by Gunk once in a while and it shouldn't tick that much.
ajwashere2
Lancer Engine Tech
Jun 28, 2015 03:03 PM
OL_DIRTY
May 19, 2015 09:04 PM
sfearl1
39
Jun 26, 2012 07:32 AM
0E3vobutt3r
Dec 25, 2006 04:31 AM
geminibby
May 5, 2006 06:03 PM
