adjusting idle
Old Sep 16, 2005 | 07:00 PM
pskelly86's Avatar
adjusting idle
Is it possible to change the rpm your car idles at?My car is idleing at about 800 or 900 rpm and it vibrates alot. When i slightly depress the gas and hold it at 1000rpm it smoothes out tramendously. I was wondering if there was a way I can correct this and how.
Old Sep 16, 2005 | 07:10 PM
twardnw's Avatar
800-900 is normal for the Lancer
Old Sep 16, 2005 | 07:22 PM
Nightblade128's Avatar
I idle at 500
Old Sep 16, 2005 | 09:39 PM
maxum17ft's Avatar
wow 500 is kinda low, i think it says in the manuel or under the hood that 700-900 is normal. mine idles usually between like 650 and 1100, lol.
y is it vibrating
Old Sep 17, 2005 | 06:20 AM
gregivq's Avatar
On the throttle body there is a screw that you can adjust. It's located right on the top and it has a rubber plug in it. Take off the plug and turn the screw. You would probably have to turn it at least 4 times to add 300rpm at idle. DO NOT raise your idle more than 900rpm!!! Unless you don't mind "check enigne light".
Old Sep 17, 2005 | 06:22 AM
Slovak's Avatar
You can adjust it, but I wouldn't screw with it. The proper way to adjust it is with the MB991502 Scan tool(MUT-II) with all accessories in the car turned off. The scan tool gets an accurate idle speed reading and also is used to hold the IAC(idle air control) motor at the basic step, which is where it has to be to properly adjust the idle speed using the screw on the throttle body. According to the shop service manual the idle speed on the scan tool should read 700 +/- 50 r/min.
TouringBubble
Oct 10, 2025 11:11 AM
VDubJCabe
Mar 24, 2016 03:05 PM
secretagentstv
Jun 1, 2015 11:29 PM
ilikeppie
May 29, 2012 08:18 PM
Tha one
Lancer Engine Tech
16
Feb 9, 2007 07:31 AM
