air fuel ratio reading
Old Nov 9, 2005 | 08:15 AM
wudbevo's Avatar
i am buying a air/fuel ratio gauge, it is not digital so it has the numbers on it. i did some searching and found on the newbi thread that one person was running like 13.3 or something?! i was wondering if anyone knows what number it should be running at, so what would be lean/what would be rich/ and whats just right?!
Old Nov 9, 2005 | 08:18 AM
blaze_125's Avatar
Not sure about the numbers, but make sure you get a wideband o2 to go with that... or you're going to end up with a christmas light party on your dash.
Old Nov 9, 2005 | 08:20 AM
wudbevo's Avatar
yeah i know i need a wideband for a more eccurate reading but i dont have 300 dollars to spend on one!
Old Nov 9, 2005 | 08:22 AM
blaze_125's Avatar
and if I remember right...
below 14.7 is richer
14.7 is perfect
above 14.7 is leaner
Old Nov 9, 2005 | 11:04 AM
N1te's Avatar
14.7 is idle and stoich.. while cruising. lol if you tune for 14.7 when WOT you go boom. I think 12.3 is ideal but i'm not sure. look up threads by Alchemist.
Old Nov 9, 2005 | 11:43 AM
Evo666's Avatar
so tune when idle? i always thought when at wot.
Old Nov 9, 2005 | 12:02 PM
N1te's Avatar
you tune at wot. you cant tune at idle much and if you do its pointless
Old Nov 9, 2005 | 12:12 PM
blaze_125's Avatar
Well... at WOT and different rpm range right?
Old Nov 9, 2005 | 12:36 PM
N1te's Avatar
yeah exactly.
Old Nov 9, 2005 | 04:09 PM
03RallyLancer's Avatar
n/a tune for about 12.6-8... i think FI tunes for about 12 flat... not forsure about FI... but im n/a and that is what mine is set too
Old Nov 9, 2005 | 08:00 PM
impetus19's Avatar
i tuned for about 12.5.. you can adjust anything over 30% throttle.. there really is no point too touch anything else b/c the ecu keeps the mixture right at 14.7 anyway. At WOT i was dipping down into the 10:1 range before I installed the emanage.
Old Nov 24, 2005 | 08:51 AM
bahamut's Avatar
It really hard to blow up NA cars, because the margin for error is bigger when comparing to turbo. You have to outright neglect it for a long time.
Cmeix
15
Apr 19, 2017 11:08 PM
Dmx3alo
Jan 28, 2017 07:45 AM
.DoT.
55
May 13, 2016 06:30 AM
19DB794
Feb 10, 2009 02:56 PM
W_evo8
Mar 3, 2008 12:52 PM
