fastest US lancer?
Old Mar 18, 2003 | 05:36 PM
blindfigure's Avatar
Talking fastest US lancer?
Whos got the fastest US lancer-
give your horepower-torque-dyno 1/4 mile times or anything else...............
Old Mar 18, 2003 | 07:41 PM
Boeturbolancer's Avatar
I'd like to think, as far as Lancers not evo's go, i'm one of the fastest. Even though i'm non-intercooled and only running 7lbs, i've managed to stomp a buddy with a 98 Mustang GT. He has free flowing exhaust, CAI, and bigger MAS. He is a manual and has times as low as 13.63 and high of 13.98. We've gone at it three times now as he states he has a launching problem. Twice from the start... i won! Once from 3rd and again i pulled and one. My times??? In about a month i'll have times and #'s till then expected to be around 200+hp to tire and loving it. If the post is still around i'll edit this/add new comment. Otherwise i'll post to be a pimp as always.
Old Mar 18, 2003 | 07:47 PM
skidd12's Avatar
GRIS has a fast lancer.... running at about 13's on the strip... though he had a problem with his pistons afterwards (at 11psi!!!) but still... i think he's one of 'em together with me and boe.... im running mid-low 14's in 1/4.... so far i only had my spark plugs changed and that's it...... just kidding haha
Old Mar 18, 2003 | 07:50 PM
zlancer's Avatar
well my times sucked cuz of traction problems cuz i'm not lucky enough like boe to have an LSD but i managed to beat 3 different WRX's, a mustang 5.0 and newer GT and various hondas and acura's.
last dyno in october:
201 wheel hp
211 wheel torque
best slip time was 15.4 burning out first and second
with grip expect mid to low 14's
Old Mar 18, 2003 | 08:35 PM
zlancer what a sucky slip time... liquid pulled way better with same traction problems you had...https://www.evolutionm.net/forums/sh...highlight=14.6
Not knocking you but you must have been really smoking the hell out of those tires. If you are pulling a newer 4.6L GT you are in the mid 14's as they run around 14.6-14.8 stock from what i've seen. Thus you are better than that 15.4! What boost you running producing those #'s. Just ask cause i've yet to dyno mine at 7lbs and i've done the head and intake manifold as well. Anyway, as i've said not knocking you but the clutch and traction probs need to go to improve that time... yikes!
Old Mar 18, 2003 | 09:43 PM
zlancer's Avatar
boost at 8 psi. and traction was really bad. everyone at the track was actually doing bad because it was one of the last days in the season and they didn't really prep the track too good so it was pretty damn slick. to give you an idea it probably would have been better if i started out in second gear.
oh yeah and the clutch does slip a little between 5k-6k rpm....so my HP output might be even more.
Old Mar 18, 2003 | 09:54 PM
Dude now i really want to know what i'm pushing. If you did that at 8lbs and i've got my engine done the way it is and Good clutch i should be right there or higher even though i'm only doing 7lbs. I may go dual stage soon as well. Just need to get some intake and exhaust temps at 9lbs. I tried it already and the car screamed. But w/o knowing temps i'm not going to even try running that. 7lbs. has been checked and rechecked. No problems with that non-intercooled.
Old Mar 18, 2003 | 10:09 PM
NTran999's Avatar
Mine is not that fast all I am running is 171 at 5psi. Did not run 1/4 yet. And mine is an auto non intercooled
Old Mar 18, 2003 | 10:27 PM
Still great for auto... i've seen your posted #'s. Auto loses almost 10hp/tq thru Torque converter alone. So lets say manual is 180hp. Add 20 more hp for 2lbs more boost and your at 200 right? Now the only variable for me is the Port/polish, header(which most don't have due to fitment issues), and hogged out intake. At worst i'd like to think i've gained 5-10 hp from them. Thing that truly makes my car quick is the LSD and clutch! Gotta love em'
Old Mar 18, 2003 | 10:35 PM
NTran999's Avatar
At least I give confidence to all the auto trannys. I am getting a boost controller so i am going to try to run 6 or 7 psi
Old Mar 18, 2003 | 11:14 PM
ROCK's Avatar
For now Z, try a two stage boost controller. Launch at 6 psi and then go for 8 psi. That would help you get out fast and still pull. Prolly good for half a second at least!
ROAD/RACE
http://www.roadracemotorsports.com/
Old Mar 18, 2003 | 11:25 PM
HobieKopek's Avatar
Gris in the high 13's as skidd said.
Old Mar 19, 2003 | 06:19 AM
I just can't wait to see what mitubishi will come up with and what will come out for the 2002-2003 Lancers
Old Mar 19, 2003 | 06:24 AM
zlancer's Avatar
yeah and i do have a dual stage boost controller...but i jus never hooked it up lol. might be a good idea to...damn i'm lazy.
Old Mar 19, 2003 | 01:23 PM
HobieKopek's Avatar
Eh...parts are pretty decent all things considered. Take a look around. I don't think Mitsubishi will be coming out with anything for the Lancer aside from cargo nets, skid plates, engine block heaters...I think you get the picture. Maybe I just missed the point you were trying to make?
