Balance Shaft Removal...
Old Jan 27, 2006 | 09:14 PM
phil_'s Avatar
I searched but didnt find much about balance shaft removal in the 4G94. They arent any kits im aware of made for our engines. Anyone know if the 4g93 balance shaft eliminator, it comes with:
Balance Shaft Eliminator Parts
MD103722
Balance shaft
bearing, rear
MD040597
Balance shaft
bearing, front
MD092785
Balance shaft
cap (plug)
MD098626
Balance shaft
stub shaft
Anyone have any ideas on this? I had this mod done on my 1G, it frees up a few extra horses, and generally increases oil pressure, soething you want in a turbo setup
Old Jan 28, 2006 | 08:23 AM
Blacksheepdj's Avatar
It is basically the same motor, just stroked out. So I'd say that the kit would probably work.
Old Jan 28, 2006 | 08:52 AM
phil_'s Avatar
yea i fiqured it has a very similar block. I think I'm going to try and pioneer something....
Old Jan 28, 2006 | 07:16 PM
sweet_bucket22's Avatar
As far as i know there are no balance shafts in the Lancer... that goes for either the 2.0L and the 2.4 for the ralliart.
I've seen both torn down and there's nothing like it in there. They use an excentric gear to pump the oil... it's driven off the timing belt like the water pump is. I know on the 1G there's another belt in there and with this you eliminate that. And those shafts are like the length of the motor and weight like 5 pounds or more. Nothing like that in the lancer motors.
If you do find one in there... let us know.
Old Jan 29, 2006 | 10:15 AM
phil_'s Avatar
Hmm, Interesting, I could've sworn i read on a older post we had them. Oh well I need to remove the oil pan soon. I'll be sure to check, maybe take a pic or 2
Old Jan 29, 2006 | 03:49 PM
otter's Avatar
EvoM Administrator
The 4G69 definitely has a counterbalance shaft. On the attached image, part number 18 is the drive sprocket for it. I'll see if I can get a better picture.
Old Jan 30, 2006 | 11:14 AM
I've had the 69 apart fully... no balance shafts that i've seen at all. If you know what one is and how the oil pump is on the 4G63 you'd see there's nothing like it in these motors.
ReivaXVrai2
75
Jan 21, 2017 07:28 PM
extremepsi
Evo 'For Sale' Engine Internals and Drivetrain
Sep 11, 2013 07:55 PM
av00va
13
Sep 1, 2013 07:26 AM
4RETECH
11
Apr 10, 2013 10:42 PM
Yamahar1
Jul 11, 2009 02:38 PM
