evo 8 motor swap
Old Feb 15, 2005 | 08:47 PM
  #46
RalliArtI4's Avatar
gosh, all these swaps...hope u have thick wallets
Old Feb 15, 2005 | 08:56 PM
  #47
UT_Evo's Avatar
Anything's possible with the right amount of money! Didja hear about the guy who swapped out his Lambo Gallardo tranny for a custom auto tranny for his wife who couldnt drive stick? 60k price tag...it's all possible, for a price
Old Feb 15, 2005 | 09:02 PM
  #48
WADADLIG_OZ's Avatar
Originally Posted by AirQuez
Adam's wasnt an E8 motor. I believe it was an E4 or an E5 swap, that he was doing. Irregardless, I know of a few other Miragers who have done the Evo swap. Excellent swap, but very costly.
Wadadlig, I dont know if you know Rem-Rock, an Evo-powered blue sedan in Orlando but he is one of them.
Oops
Sorry the red valver cover fooled me
It's the first EVO swap stateside I have seen posted. I did not know that there was one right here in Orlando That I'd love to see.
WADAD
Old Feb 15, 2005 | 09:11 PM
  #49
BeefyEvo's Avatar
Originally Posted by ear60008
This is just a question. Is it worth the money to buy an engine, turbo, tranny, brakes, and installation. Plus your going to have to tell your insurance about it in case you total your car. Why not take all that money and put it down on a faster car?
Street sleeper........ Imagine waveing hi to an OZ then accelerating to show off the evo ... but theres something wrong ?!?!?! hes keeping up !!! OMG he pulling on you ! AAAHHHH ..... id like to see it done. Be kinda funny messing with Vettes and Cobras in ur OZ Rofl !! GL man
Old Feb 16, 2005 | 07:18 AM
  #50
redozrally's Avatar
Originally Posted by HobieKopek
You have no idea how annoying those posts are. ^^ As much as I think these swaps are stupid, it's a Lancer tech thread not a car swap thread.
then why read it??
Old Feb 17, 2005 | 01:53 PM
  #51
lancershounen's Avatar
I figured im only gonan do a body kit, seems like too much trouble to do a swap and all.
Old Jun 4, 2005 | 11:10 PM
  #52
Rob'Z's Avatar
My question is does an EVO VIII 4G63T block bolt up to any FWD trans? This is going in a mid-mounted rear-drive setup so motor mounts etc. make no difference. I need a FWD trans to bolt up to EVO VIII block.
I was planning on going with an EVO RS trans since it has LSD but after looking at the EVO trans the transfer case may be an issue. Has anyone seen an EVO trans with the transfer case removed? Is it possible to connect a half-shaft directly to the trans and then fab a side plate to contain the fluid?
Old Jun 5, 2005 | 08:43 AM
  #53
HobieKopek's Avatar
Rob, try asking that in the Evo forums. Most Lancer people don't really have much hands on experience with the Evo transmission or transfer case in the way that you're asking. Anyway, I think you might get the response you're looking for there.
Old Jun 5, 2005 | 03:31 PM
  #54
Gunshin's Avatar
All you need to make a 4G63T FWD is a 3G Eclipse 4G64 bellhousing and your current transmission. Manual and auto bellhousings are different, so get the appropriate one.
Old Jun 5, 2005 | 07:12 PM
  #55
Rob'Z's Avatar
So an EVO VIII 4G63 will bolt to a 3rd gen Eclipse bellhousing bolted to a Lancer (or other FWD) trans?
I think this may be the answer I was looking for.
Old Jun 5, 2005 | 08:49 PM
  #56
HobieKopek's Avatar
Or you could get REALLY lucky and have a Mirage guy answer. Gotta love em.
Have you checked into 1g GST motor/tranny options? I don't know if it would suit you quite as well, but it's certainly worth considering if you haven't.
Old Jun 5, 2005 | 10:58 PM
  #57
Gunshin's Avatar
We've had more time to think things over than you guys.
Oh, I forgot to mention that there is a slight issue with the starter motor and the turbo since the 4G64 puts the starter on the front of the block. It puts the starter in front of the turbo inlet, which obstructs the suction pipe path. Guys in PR have moved the starter to the rear, and a dude in OZ made a custom manifold to shift the turbo.
Rob, if you aren't in a rush, I will have a similar swap (hardware wise) underway and will at least have the motor, bellhousing, manifold and turbo in dry-dock within the next month or two. I can let you know what to expect, or you could come check it out.
Old Jun 5, 2005 | 11:07 PM
  #58
cyberninja's Avatar
Originally Posted by QuickSilver_OZ
I'm actually workin with a perfomace shop to get that motor in my Lancer. They told me that it's a direct bolt on, but I will have to change my tranny. They are still doin some research so I can get this done.
By the time you finish with the motor swap and the expensive **** tranny, you could of put some money down for the evo and took the rest and got a huge turbo charger to finish. Not good use of your cash IMO. I wish I had money that grows on trees like that.
Old Jun 6, 2005 | 11:33 AM
  #59
Rob'Z's Avatar
Thanks for all the info guys, I appreciate it.
Gunshin-I am not in a rush, still considering my options. I would love to see the parts in person when you get them. I hve tried eyeballing them in different cars but it just isn't accurate enough.
AFAIK the 1G, 2G Exclipse drivetrain is turned 180* in the engine bay? Also I have seen many more upgrades for the EVO 4G63.
Old Jun 6, 2005 | 12:59 PM
  #60
HobieKopek's Avatar
There are ****tons of mods for both, but the Evo powerplant is a more refined version, and the tunes are more aggressive. I think the real benefit to looking into DSM 4g63T's would be significantly lower initial cost. The Evo motors tend to significantly more.
