idle adjustment
Old Mar 28, 2018 | 02:21 PM
Lancer-of-OZ's Avatar
Smile
just wanted to join to say thank you for this thread. there are 3 or 4 like it on evolutionM, but this is the only 1 with the correct location and a nice picture.
it is the top screw. and i had to turn mine about 6 full turns before any difference was made. mine was screwed way out, and idled between 1400 to 2000 RPMs with a/c off, and 1000 to 1500 with a/c on.
now, it stays between 700 and just under 1000 RPMs regardless of a/c being used or not, car warmed up.
i've also changed my IAC twice, 1 from a junkyard, 1 brand new generic, and 1 original to my car... the 1 (original) i have now jumps RPMs at idle, but only about 200 range. the junkyard IAC does the same range, but idle is 300RPMs higher at all ranges (so 1000/1250 at idle). then the eBay new 1, holy crap. car idles at 4500RPMs. just a garbage part. if you need one, hit your junkyard.
Old Sep 27, 2019 | 07:52 PM
Joseph Smith's Avatar
Originally Posted by TEJ
Have the same problem, i turn it a lot and the idle does not seem to go up or down.
Y'all retarded, theres 3 adjusting screws with allen key and 5/16 locking nut. One is for fuel pressure regulator. One is closest to t b. Plate and one is for throttle cable.
Old Sep 28, 2019 | 11:49 AM
ambystom01's Avatar
You responded to a 13 year old post to call the guy a retard. Yeah, you sure showed him...
audiofan
Aug 14, 2016 08:47 PM
9!'clipseDOHC
Jan 9, 2016 10:21 PM
sleepy_rps13
22
Jan 30, 2015 10:01 AM
evo4life400
Mar 13, 2010 01:25 PM
TEJ
Lancer Troubleshooting
Feb 9, 2006 09:30 AM
