NSC Engine Damper Review
Old Aug 29, 2006 | 12:22 PM
Lusion's Avatar
Good to hear your review.
Old Aug 29, 2006 | 12:43 PM
crypto's Avatar
Former Vendor
Originally Posted by sdhes
Maybe get access to a grinder and buy some heat resistant paint. You will also need a decent socket set, a 6-8" extension, and some sort of breaker bar to get the strut tower bolts and the motor mount bolts off.
well i have a decent socket set. grinder is not likely. i really am not bothered on the appearence of it.
What do you mean by breaker bar?
Old Aug 29, 2006 | 12:48 PM
Wallesasuaz's Avatar
It's a bar w/o the rachet making portion. I has the end for the socket and gives enough leverage to remove a nut.
Old Aug 29, 2006 | 12:52 PM
crypto's Avatar
Former Vendor
oooohhh. ok, yeh im pretty sure i got one of those., if not i know someone who does.
so how long did it actually take you to install it.
i have pretty bad luck when doing anything, is there much chance of me breaking anything?
(i somehow managed to screw up my touch-up painting this weekend, instead of 2 big scratches on my car, i now have 2 dark silver spots)
Old Aug 30, 2006 | 04:05 AM
sdhes's Avatar
Its real easy. Only have to take four nuts off (2 strut tower, 2 on engine). It comes with good intructions too, which is always a plus. If you can get a breaker bar, either the one in the pic, or a home made one, it will make it extremely easy to losen and tighten the nuts. Once it's on, Just dont over tighten it and blow out your bushings on the connecting arm (or whatever they called it). Tighten it until you see the bushings compress some and your done. The grinder may be necessary for it to even fit on the strut tower so you may want to look into it, someone who has one, borrow, whatever. A Dremel with a grinding stone may be all you need, so you might want to keep that in mind. You will be happy with the end result though. Especialy as you continue to mod, and it will help your stock mounts last. I felt a very noticeable difference, especialy going from just the stock mounts and my mods to now having it stay put when I hit the gas.
David Buschur
477
May 28, 2020 07:16 PM
Lucas English
184
Feb 5, 2017 10:37 PM
BENEVO
Oct 6, 2014 03:47 AM
YIfuEVO
Jan 4, 2014 07:42 PM
pennies_hatchie
May 24, 2010 06:24 PM
