Oxygen Sensor Question
Old Jul 29, 2006 | 09:01 AM
03lancOZ's Avatar
I just installed my RPW header and downpipe, and RRM Magnaflow cat, but the positioning of the O2 Sensors is a bit odd... The RPW downpipe has a bung almost at the very end of it, inches from the cat. And the RRM has a bung on the Cat like 4 inches from the one on the down pipe... I cannot imagine the two are going to read anything different... Is this going to cause any problems?... Just curious... I have yet to hook the plugs of the O2, because the one on the down pipe needs to be extended, and I was unable to remove the one on the old cat, so I am going to pick up a new one in a little bit...
Any input on this would rock... Thanks guys..
Steve
Old Jul 29, 2006 | 09:10 AM
Blacksheepdj's Avatar
Best idea - flip the cat around so the O2 sensor comes after the cat material. You have to extend the wiring about 15" to do it, but it'll clear up any CEL/SES issues.
Old Jul 29, 2006 | 10:03 AM
03lancOZ's Avatar
gotcha... it's hot as ***** here, so Ill do it tomorrow morning... Thanks
Old Jul 29, 2006 | 10:56 AM
03lancOZ's Avatar
I just picked up a universal bosch o2 sensor and it has like an 18"+ cable with it, so that will work out... I am bored today, so I am going to go ahead and swap the cat... I let you know how everything turns out...
Old Jul 29, 2006 | 11:55 AM
Best of luck.
Old Jul 29, 2006 | 12:03 PM
03lancOZ's Avatar
Thanks.... It was pretty cake actually... And the cable is long enough to reach all the way inside where the plug is... Now I just have to extend the other O2 cable and everything should be good... Thanks again...
Old Jul 29, 2006 | 03:21 PM
03lancOZ's Avatar
Well so far everything looks good... no CEL yet, but we will see... Thanks....
bossssman38
Feb 15, 2013 06:32 PM
A.J.'s_EVO
Jan 9, 2009 06:51 PM
coolguycooz
12
Feb 5, 2007 02:27 PM
orikosan
11
Jun 21, 2004 11:05 PM
Lil red '03
Lancer Engine Tech
Mar 18, 2003 06:51 PM
