Head question for anyone with answers
Old Aug 16, 2006 | 11:17 PM
blackout24's Avatar
I want to cut my head by .005 is that possible or is that too much
Old Aug 16, 2006 | 11:20 PM
03lancOZ's Avatar
cut your head?... or bore?... are you trying to change the compression by chopping some of the top off?... just curious
Old Aug 16, 2006 | 11:30 PM
blackout24's Avatar
what I'm trying to do is get the compression higher by chopping the head by .007 or .005 then putting a turbo in to it later.
Old Aug 16, 2006 | 11:31 PM
blackout24's Avatar
and my car is a 2003 lancer es.
Old Aug 16, 2006 | 11:33 PM
03lancOZ's Avatar
I may be backwards, but I thought you want to lovwer the compression with forced induction... and you can add gaskets to do that...
Old Aug 16, 2006 | 11:42 PM
blackout24's Avatar
but don't you need to have higher compression to gain power?
Old Aug 16, 2006 | 11:57 PM
03lancOZ's Avatar
for a N/A set up, yes you will benefit from it, but if you plan on going F/I just keep it the way it is....
Old Aug 17, 2006 | 01:03 AM
blackout24's Avatar
but will it hurt the engine if I go F/I If I do chop it?
Old Aug 17, 2006 | 01:07 AM
03lancOZ's Avatar
once you chop it, only way to repair that is to get a new head... F/I performs better @ lower compressions.. I dont believe it will hurt you, but you would be pretty much kicking yourself in the rear... Well unless you plan on getting a new head already, go and get the RRM one...
Old Aug 17, 2006 | 01:20 AM
blackout24's Avatar
kewl thanks for the info i'll be back for more soon
Old Aug 17, 2006 | 08:01 AM
airlinevomitbag's Avatar
I don't know what the clearance is with the valves and pistons as stock but I bet it isn't much. I don't think its a good idead to bring it any closer without some factory documentation on those clearances.
Old Aug 17, 2006 | 09:59 AM
SLVROZ_03's Avatar
Just keep the compression the same... Don't mill unless you have reason to believe the head is warped and really needs it. But, I somehow doubt that...
