mas airflow sensor(or somethin like that)
Old Oct 21, 2006 | 08:51 AM
Blacksheepdj's Avatar
Originally Posted by sadude
Thanks for the breakdown...but where would one install a MAP sensor...does our intake manifold have like a port for something like that or would you have to do a custom install?
Also I guess you would have to re-wire your MAF plug to plug in to the MAP instead?
Not sure. Ask HobieKopek, as he has MAP.
I'd assume so on the rewiring...
Old Oct 24, 2006 | 06:44 AM
rhyzin's Avatar
Originally Posted by airlinevomitbag
I don't know about leaner across the board, the computer won't be as reactive. I talked about gassing it and the computer dumping gas for the signal but the air not being there yet, the same would be true if you let off the gas some, the computer stops dumping gas but the volume of air hitting the throttle body is still high causing a lean condition.
oops. yeah, i think you're right after actually sitting down about it. good call. i was thinking in terms of volume, not time. jeebus.
Old Oct 24, 2006 | 07:38 AM
phil_'s Avatar
You can use pretty much any port after the TB on the IM plenum. Then run the vacuum hose to the MAP sensor/computer, wire the sensor in, and your ready to go.
When you do this mod you are deleting the stock MAS and you bypass the stock ecu (you need a standalone/emanage). In some cases where you are controlling fuel/igntion you can delete the stock ecu completely.
blown1
Dec 15, 2010 01:54 AM
Blackout-VIII
Oct 29, 2007 01:00 PM
Khoranic
Lancer Engine Tech
Sep 21, 2007 04:37 AM
EVOllie
Jun 24, 2007 02:52 AM
Hiboost
Sep 1, 2006 06:21 AM
