Pretty bad ticking on cold start? any info, please help!
Old Dec 18, 2006 | 02:45 PM
Blacksheepdj's Avatar
Probably a loose belt, bene. Most likely, the higher RPMs are just moving it fast enough that it's not as slack. Just tighten the tensioner a bit...
Old Sep 11, 2007 | 02:40 AM
EarsLikenElf's Avatar
To follow up, I have put 20k miles on my car since the ticking (driving about 80 miles or more a day) and the tick remains, has not become worse, and the car still drives great.
99k miles!!! woohoo
Old Oct 10, 2007 | 12:05 AM
bagice's Avatar
The Lancer has little hydrolic lifters. The ticking noise is those lifters running without being primed with oil. It's very common. Just fallow the advise given of not running the car hard untill the noise goes away. There is a chance of collapsing the lifter.
Old Oct 10, 2007 | 12:09 AM
kungfugirl's Avatar
pretty sure its a typical mitsu trait.
Old Oct 11, 2007 | 08:46 PM
lancer2show's Avatar
lifter ticking noise....i think the only way to fix is it is an oil dropper
Old Jan 5, 2008 | 12:11 PM
Jersey Dino's Avatar
since there are soooo many threads about strange ticking noises I will post this link for everyone. hopefully we can figure out if anyone/everyone is having the same or different noise coming from their car.
http://www.youtube.com/watch?v=2vkKzgVstzc
On a side note. after the car is warm it will sometimes go away.
Old Jan 5, 2008 | 01:11 PM
voidmind's Avatar
Ah, I'm glad I came across this thread. I just noticed the noise recently, ever since its gotten real cold here. It ticks at first then goes away quickly after the engines warmed up some. Thanks for the info.
Old Jan 5, 2008 | 02:36 PM
mine woudl warm up and go away but sometimes it doesnt go away. its annoying. not that the sound bothers me all that much, its the idea of not knowing what is causing it. especially since I Have never touched anything with the valvetrain/drivebelts/timing etc
Old Jan 5, 2008 | 02:46 PM
ambystom01's Avatar
It's a normal mitsubishi thing, nothing to worry about.
Old Jan 5, 2008 | 02:48 PM
coal's Avatar
I use 0-30 and I dont have a tick. I dont get too cold of tems here, high 20s-low30s is the coldest I see.
Old Jan 5, 2008 | 03:20 PM
Tree's Avatar
Originally Posted by MLancer1986
I have an '03 Lancer es and it ticks at startup. I have about 90k on it
mine is a 06 with almost 50k miles on it. my friend also told me it was normal and that your car will make plenty of weird scary sounds when its cold and just let it warm up and they will go away. cus oil is think and cold and the belts are cold and stiff and they all need to warm up. started after i got my oil changed the first time and scared me for a while but i know its ok now. thank god.
Old Jan 5, 2008 | 03:23 PM
ok cool. well I will see what it does after some considerable warming up(read beating the hell out of it)
Old Jan 6, 2008 | 06:34 AM
mcgarvey's Avatar
Mine ticked like crazy since the day it rolled off the dealer lot. At 44k I adjusted the valve lash to exactly the factory spec, and no change. It's nothing to worry about, these are just noisy engines.
Old Jan 6, 2008 | 04:27 PM
c900t16's Avatar
mine sounds like this! I get a valve tick (or atleast thats what i thought it was) but it more or less sounds like a belt. and its coming from the same spot as in this video ( i know i dont have an evo, but the belts are on the same side).
it also goes away after the engine is warm,,,sometimes takes longer than other times.
Ian0611
16
Sep 27, 2023 01:42 PM
Hassan
103
Aug 5, 2023 11:37 AM
KJS
Oct 4, 2016 06:58 AM
TJSAP00
25
Dec 27, 2011 09:39 AM
dipsetinallday
Jun 28, 2009 11:28 AM
