Timing Belt over 70k = mishap!
Old Dec 7, 2006 | 03:53 PM
gbwaacha's Avatar
Well my car died about a month ago and i just finally got it back. Turns out the timing belt broke and bent 12 valves. It cost me $2100 for everything to get fixed including all new belts. I deffinatley recoomend getting that thing changed at 60k as it should onyl cost a few hundred. But anyhow I bit the bullet and the car is back up and running greta except for a power stearing pump leak that i need to take back to get fixed. But anyway happy boosting
Old Dec 7, 2006 | 04:01 PM
Myszkewicz's Avatar
That's a painful lesson to have to learn. I've never had one break because I let it go too long, but I did have one break 10k miles too early. Bent a bunch of valves, broke two exhaust valves, trashed head, holed #2 piston, dinged up the #2 cylinder wall. Pretty much killed that car for me.
Old Dec 7, 2006 | 04:05 PM
FlipBoiFlava242's Avatar
oh wow! thats crazy man! good to know ya got it back up n running though. Its just scary finally reading a story where it actually happened to someone cuz ive read so many threads about the timing belt change. Lesson learned eh?
Old Dec 7, 2006 | 04:12 PM
gbwaacha's Avatar
i would say its deffintlaye a lesson leraned...its just abd timing becasue the week before ii put 900 into gettin new brakes and stock suspension and some exhaust work done...oh well
Old Dec 7, 2006 | 05:34 PM
atilla's Avatar
that sucks! sorry to hear about all that. i replaced my timing belt at 103k and i am glad i did it then. it wasn't looking too good and i am glad that it held until i was able to repalce it.
good to hear that your lancer is back in working order though.
Old Dec 7, 2006 | 05:53 PM
DRFTKNGG's Avatar
Could have been worse and trashed all the pistons.
Old Dec 8, 2006 | 08:07 AM
Sicktght311's Avatar
Just be glad the lancers are SOHC. I had a dsm prior to my lancer with the 4G63 DOHC. I had a small fender bender and my belt snapped 2 days later cuz where he hit me cracked the timing cover causing a little piece to jump into a sprocket 2 days later. Bent all 16 valves, trashed the head, scored the tops of the pistons, just an absolute mess, i was lucky because since it was "caused by the accident" that guy's insurance covered it all since he was at fault. But still, broken timing belts are just an unnecessary evil. You would think car manufacturers would have adapted metal TB's or something less prone to breakage after 60k long ago.
Old Dec 8, 2006 | 09:25 AM
SLVROZ_03's Avatar
Thus one reason Nissans are somewhat superior... Metal timing chains... They can be loud and a pain in the neck if it needs work though!
Old Dec 8, 2006 | 09:26 AM
Blacksheepdj's Avatar
Like the timing chain in my '69 Camaro?
Obviously the manufacturers consider the rubber ones an "upgrade" from the old days.
Old Dec 8, 2006 | 09:34 AM
gregivq's Avatar
I always wonder...when a timing belt snaps there's plenty of damage to the head of the engine and possibly the pistons. Why not just buy a new engine and slap it in the place of the old one? Wouldn't it be cheaper?
Old Dec 8, 2006 | 09:36 AM
crypto's Avatar
Former Vendor
i probably should get my timing belt changed. hopefully it will hold out for another month till i get back from vacation.
Old Dec 8, 2006 | 09:37 AM
Hmm never thought about that...how much do our motors go for?
Old Dec 8, 2006 | 10:03 AM
gregivq's Avatar
From $300 to $700 depends how many miles and where do you get if from. Usually $500 is enough to get a decent bang for a buck and slapping it in is pretty easy.
Old Dec 27, 2006 | 03:49 AM
mrblob20's Avatar
had mine replaced at 100 000 miles (not km)... it looked as good as the new one. I almost thought they didn't replace it when i got my old part back ! hah
Old Dec 27, 2006 | 11:40 AM
deltron79's Avatar
so i have 107k on mine, i guess i need to get it swapped asap, only 4.5 yr old...but i knew about 40k ago i should have it done, guess i gotta bite the bullet. whats the most amount of miles anyone has on one timing belt?
