Intake manifold and TB install problem
Old Jan 4, 2007 | 10:15 AM
XAlliedYouthX's Avatar
I just put the manifold and TB on my car lastnight and now the idle is rough as hell plus it wants to stall out constantly and it sounds like there is a horrible valve tapping. I can't find any lines that aren't hooked up correctly and I really can't think of what could be causing it.
Old Jan 4, 2007 | 10:30 AM
Blacksheepdj's Avatar
Weird. Did you drop a washer into the head or something?
Old Jan 4, 2007 | 10:44 AM
All hardware was accounted for. I still have to refill the coolant but I can't imagine that being it.
Old Jan 4, 2007 | 11:02 AM
krnzzang84720's Avatar
did you reset ECU??
Old Jan 4, 2007 | 11:07 AM
I unplugged the terminals, let it sit then put them back on. I don't know if it could have anything to do with it but the CEL is on from the header and the Piggyback is also in there. Just trying to get anything out there that could help figure out what the problem is.
Old Jan 4, 2007 | 12:21 PM
ambystom01's Avatar
Maybe you have a leak.
Old Jan 4, 2007 | 02:05 PM
Walkingchaos's Avatar
^ im voting for vacuum leak, those can be a pain in the ***.
Old Jan 4, 2007 | 02:31 PM
I talked to a guy at work that used to be a mechanic and he said it could be a leak from one of the injectors so I'm hoping on that be it.
Old Jan 4, 2007 | 03:36 PM
ROCK's Avatar
Call us but it sounds like VACUUM LEAKS..... That is really all you can do wrong on install.
ROAD/RACE
Old Jan 5, 2007 | 07:52 AM
So I looked this morning and I somehow lost one of the black insulators that goes between the injector and the maifold. Who knows where that ended up on my driveway but I'm going to have to go buy a new one anyways. I'm definately not looking forward to paying the $70 or whatever they'll charge for me to buy the full injector just for that damn 2cent piece.
Old Jan 5, 2007 | 08:48 AM
Wait, why are you buying a whole injector if you lost an O-ring? You know you can just buy the O-ring, right?
Old Jan 5, 2007 | 08:51 AM
Just found out that I could a second ago. I had been told previously that I probably had to get the entire injector. Thankfully not.
Old Jan 5, 2007 | 11:26 AM
CadiLuva's Avatar
hopefully you found the problem.. good luck..
BTW any pics??..
Old Jan 5, 2007 | 11:34 AM
I got the last 2 seals from the local dealer for around $1.50 each. I'll have some pictures once I get it all running right but it won't be anything special to see cause I got the manifold unpainted to it all looks stock under the hood.
Old Jan 7, 2007 | 01:19 PM
First I must say that these past few days have sucked. All thats been on my mind is WTF was wrong!
Ok so after check all of the lines numerous times over the past few days I figured it couldn't be them. Lastnight around 11:30 I thought it could've been something with the piggyback so I figured what the hell and took that off. The car ran even worse with it off. So today I went out there and just took it all off, TB+IM+ and all the other junk. When I got down to taking the bolts and nuts off that attach the manifold to the head I found that there were 2 that somehow didn't have bolts in them at all and after looking at the gasket I could see that there was something leaking into the closest port. It was the 2 that I drew arrows to on the attached picture. The one was hidden by the TB bracket so thats probably how I missed it.
I feel a bit stupid for not noticing that we didn't put those in but I did have 2 mechanics working with me so I think they should feel even worse. I still need to get the piggyback in there and then I'm going to go have some fun and see how it goes.
