head 4g94
Old Feb 21, 2007 | 08:47 AM
Carrier's Avatar
head 4g94
ok my new project for my head 4g94 is near finish but i need valve. does it have valves in stainless which are compatible with our head? at present I have valvesprings aftermarket of camaro lc1, a custom cam racing for 8000rpm,fidanza cam gear, head ported.I need valve
I saw that with valve of VW vr6 they would be possible to modify them for our 4g94 butis very custom...
Old Feb 21, 2007 | 08:55 AM
Alchemist's Avatar
Why not just buy a new set of the stock valves? Getting too custom with valves can be bad, as you will likely grind through the case hardened layer and expose the heat intolerant, rust prone, softer steel underneath.... unless you have an industrial style heat treat shop at your disposal. Then it could work.
How do you plan on making your lower end handle revving to 8K RPM? And you're aware that the fuel cut is at about 6250 RPM, right? Even revving to 7K (if you haxored teh ECU) would be a no-no on a stock crank and pistons.
Old Feb 21, 2007 | 09:28 AM
Carrier's Avatar
I don't have a stock block.. and i have aem ems like computer.I have a good setup turbo and many custom part. The 4g94 can ride 8000rpm but the cam oem is to bad for this.. I made a custom cam for 8000rpm with the good duration...
Old Feb 21, 2007 | 09:29 AM
Carrier's Avatar
I want stainless valve because the temperature and the head is very hot
Old Feb 21, 2007 | 01:07 PM
Mirage2.0's Avatar
What the duration on your cam?
Live4Redline
Lancer Engine Tech
19
Jan 9, 2017 09:55 PM
llt-racing
Lancer Engine Tech
30
Sep 14, 2011 02:06 PM
holycrap300
Lancer Engine Tech
31
Mar 5, 2010 04:10 PM
Fifty
Aug 5, 2008 09:27 AM
arptunner
Lancer-Mirage Compatibility Forum
26
Jan 17, 2008 04:10 AM
