Old News!! 4G64 Swapped Into A 2002 Lancer
Old Aug 31, 2009 | 09:48 PM
  #571
rpm_ruffryders's Avatar
Originally Posted by senate6268
Swapping diffs will work. Mitsu part #'s confirm it.
Originally Posted by darkmitsu
she is running...with the assistance of my wifey.... will post update later tonight maybe video if we can figure it out..and axles will be here by wednesday... moving this off into my own build thread now here it is....
https://www.evolutionm.net/forums/la...ml#post7457971
you dont need custom axles. Senate confirmed the differential part numbers. if you just swap out the diff's and keep the eclipse gears you should be able to keep your Lancer axles.
OMFG!! THE SUSPENSE IS KILLING ME!!!!!!!!!!!!!!
Old Aug 31, 2009 | 09:54 PM
  #572
darkmitsu's Avatar
thanks for the info, you and senate keep telling me that, but Im just trying to find out if we can do it with axels from other models.. The ralliart axel dont work.... Swapped the differential...
Old Aug 31, 2009 | 09:58 PM
  #573
right on...gotta search every possible avenue on this, right. something I didnt have time to do.
Old Sep 1, 2009 | 04:30 PM
  #574
senate6268's Avatar
thanks for the info, you and senate keep telling me that, but I just am trying to find out if we can do it with axels from other models, rather than having to take the tranny to a shop to get the differntials swapped... I ordered the ralliart axel's , if they dont work, I'm think maybe trying the evolution axels...
***CORRECTION***
The driver side Ralliart axle WON'T fit. As it turns out, its not the differentials that are the same part #, but the diff cases. Both the Ralliart and 3G Eclipse use a different spider gear set for the diff. I'm sorry for all the confusion. The best and most simple solution at this point is swapping the Lancer front diff into the Eclipse transmission and using the stock Lancer axles.
The passenger side axle won't work because it utilizes an intermediate shaft, which the 4G64 and 4G94 didn't. Evo axles won't work because both of the inner CVs are female due to the transfer case.
Old Sep 1, 2009 | 08:00 PM
  #575
darkmitsu's Avatar
Thanks for that clarification senate, You are a wealth of mitsubishi knowledge , How do you know all this stuff ... I think I'm gonna go with the differential swap route I figured out how the trans comes apart tonight , you wont need to pay top dollar to a transmission shop to do this for you...
Old Nov 2, 2009 | 07:41 AM
  #576
AMT's Avatar
AMT
So I read most of the 39 pages of this thread and like others I've come to the conclusion that an engine swap into my 2002 Lancer OZ Rally would be more cost effective than going turbo on the 4G94 (sorry RRM). I've begun the process of looking for parts and was wondering if anyone had any recommendations as to where to get them (for a rebuilt engine on eBay its about $1,200+). Also does the engine have to be from a specific car? There are a dozen or more makes that use the 4G64.
I also have two NA mods (K&N SRI and RRM pully). Would I be better off returning/selling them or could they be useful somehow?
My car has an automatic transmission, but from what I've read I can "easily" swap to manual OR keep it automatic if I choose to. Is this correct?
Rpm, what NA mods did you have for the 4G64? Was it everything you listed on the frontpage or were there more you had to get you up to 164 WHP? I'm sure you've answered this many times but I couldn't seem to find a clear answer anywhere ...
And I know it was 3 years ago but sorry about the car! What are you driving now?
Old Nov 9, 2009 | 04:24 AM
  #577
Jehuty's Avatar
The answer is there bro...you need to read again...
In any case, he is currently looking for a shell to get the swap done again.
Old Feb 24, 2010 | 10:08 PM
  #578
bvasquez12's Avatar
so what kind of 1/4 mile times would someone with these numbers in a lancer expect?
Old Mar 10, 2010 | 09:55 PM
  #579
japordie's Avatar
+2
Old Apr 13, 2010 | 11:50 PM
  #580
bvasquez12's Avatar
Got the swap done! but i dont feel as much of a power difference as expected..
Old May 16, 2010 | 07:46 AM
  #581
maximuskio's Avatar
probably because you just went from 120hp at the crank to just under 150hp, it's not like you jumped 100+ or anything, but now at least you have a stronger base to build off, and the new engine is much more responsive to bolt-ons
Old May 16, 2010 | 02:56 PM
  #582
bvasquez12's Avatar
yea but it is actually slowre than before, as soon as i get my tactrix cable im going to flash the 4g64 settings onto my lancer ecu, hopefully it will run alot better.
Old May 18, 2010 | 04:13 PM
  #583
qaz003's Avatar
well that blows
Old May 19, 2010 | 03:00 PM
  #584
bvasquez12's Avatar
Well yea it does, but i had alot of things that werent quite worked out, i found two vacume leaks and kept getting a cel for o2 sensor, so i fixed the vacume leaks and the cel went away, now it should run alot better. And im going to get tuned on the 31st
Old May 24, 2011 | 10:28 AM
  #585
MurphDurph's Avatar
1 year bump!!!
any updates?
