Intercooler
Old Jun 9, 2003 | 11:43 PM
blaze_125's Avatar
Intercooler
Might be a stupid question for many people, but if I don't ask I'll never know.
What does an Intercooler do. What's its use?
Old Jun 10, 2003 | 04:17 AM
near_REDLINE's Avatar
An intercooler or charge air cooler is an additional component that looks something like a radiator, except air passes through the inside as well as the outside of the intercooler. The intake air passes through sealed passageways inside the cooler, while cooler air from outside is blown across fins by the engine cooling fan.
The intercooler further increases the power of the engine by cooling the pressurized air coming out of the compressor before it goes into the engine. This means that if the turbocharger is operating at a boost of 7 psi, the intercooled system will put in 7 psi of cooler air, which is denser and contains more air molecules than warmer air.
Old Jun 10, 2003 | 11:56 AM
blaze_125's Avatar
Do we absolutly need a turbo setup to use an Intercooler?
Old Jun 10, 2003 | 02:09 PM
mobius97's Avatar
At low boost levels no. But if you want to boost at a somewhat high level you WILL need one.
Old Jun 10, 2003 | 02:14 PM
mobius97's Avatar
This is untrue. You are forgetting about pressure drop here. If the turbo is actually putting out 7 psi, your intake presssure is going to be at a different PSI, due to the drop. So if you have a intercooler that has a drop of say 2 PSI and you are reading 7psi at the intake mani the turbo is actually putting out 9psi.
Old Jun 10, 2003 | 06:50 PM
i agree
Old Jun 10, 2003 | 10:42 PM
blaze_125's Avatar
Thanks guys!
Old Jun 13, 2003 | 02:52 PM
HobieKopek's Avatar
And AN intercooler useless if you're not turbocharged or supercharged. I think they misread your second question.
EDIT: Derf. Much better.
5LEEPERISAH23I
Nov 27, 2011 05:12 PM
Coltar
55
Sep 10, 2010 11:50 AM
vplukas101
13
Jun 3, 2010 04:39 PM
Werd
15
Jun 15, 2009 11:38 AM
JSYEVO
20
May 7, 2005 11:48 PM
