ROAD/RACE- Pulley 2008 Lancer
Old Aug 5, 2007 | 09:42 PM
  #211
ROCK's Avatar
Originally Posted by Eagles GTS
Quick question. Does the pulley make the rpms climb faster. This may have already been discussed but Im not sure.
It does exactly that.
ROAD/RACE
Old Aug 5, 2007 | 09:56 PM
  #212
jRox's Avatar
wee i found someone. thanks suggestions.
Old Aug 5, 2007 | 11:18 PM
  #213
CamShaft's Avatar
please read some other posts before giving the pulley a try...it can be hazardous to your engines health in the long run
Old Aug 5, 2007 | 11:47 PM
  #214
Eagles GTS's Avatar
Is this true Rock. What kinds of hazards CamShaft
Old Aug 6, 2007 | 12:51 AM
  #215
stEVOx's Avatar
if installed properly u should have no problems, i have one on my RA, nothing wrong, and plenty of other owners have one from RRM, the only thing i have read is a squel that may happen after a while, but that is just normal wear on the belt
Old Aug 6, 2007 | 01:48 AM
  #216
Eagles GTS's Avatar
so the squeal meas to replace belt
Old Aug 6, 2007 | 02:08 AM
  #217
stEVOx's Avatar
yeah, that or maybe its slipping off and needs to be put on properly
but if u are so concerned with warrenty(which apparently mitsu doesnt have ) then dont mod ur car,
i used to be scared about that, but 2 months after i had the car i started and love it, just wish i had more money to keep it up
Old Aug 6, 2007 | 02:11 AM
  #218
Eagles GTS's Avatar
Im not "so" concerned about it but it is good to keep the warranty if you can. Also, if anything does happen, I can take off the pulley and put the OEM on. They wouldnt know, right?
Old Aug 6, 2007 | 04:38 AM
  #219
MITVRX's Avatar
^ Yes it does. Lighter rotational mass > faster rotation > rpms climb faster
Old Aug 6, 2007 | 08:27 AM
  #220
SeRious08's Avatar
Again, pulley took me 10 minutes to install.
Old Aug 6, 2007 | 02:28 PM
  #221
Blacksheepdj's Avatar
50-50 chance. My understanding is that they'd kinda have to know what they were looking for. But it's hard to say without talking to a tech.
In the end, just remember that your motor might be fine. Everyone is overreacting and having kittens about their motor grenading tomorrow because of the pulley. This will not happen. The only concern is that over a LONG period of time, the motor could possibly wear down faster than it would without the pulley. As with any "performance" part, this is a choice you have to make: "stock & safe" or "modified & faster" . . .
Old Aug 6, 2007 | 03:01 PM
  #222
show time's Avatar
^ +10
The pulley is great I love it and it does improve car performance .
Old Aug 6, 2007 | 06:38 PM
  #223
jRox's Avatar
that "speedtech" thread got me shook.. well cant install it anyway. parents are waaaackkkk
Old Aug 6, 2007 | 10:17 PM
  #224
ROCK's Avatar
Don't be shook. Wow Speedtech is here to bash our pulley? What about other pullies? What about turboing your car. You guys give more attention to a pulley on a car you prolly won't keep long enough to pay off. IF you were to have problems, IF, it would be way down the road. Meantime running the wrong fuel or oil will do worse damage to a motor, Not to mention all those AFC guys trying to tune their cars without knowledge or equipment (WIDEBAND etc...) It is quite a bias crowd. Keep your cars stock boys. Otherwise, if ou have a little faith or *****, get the pulley. This is quite lame really in the context of mods people do..... motor oil to turbos!
ROAD/RACE
Old Aug 6, 2007 | 11:01 PM
  #225
CamShaft's Avatar
Not saying this mod will make you car blow up in 5000 miles. But a harmonic balancer is there to balance the stress on the crank shaft.. if the crank does ever break, cranks break in only two ways. On a 45 degree on the fillet (the curved part before the journal, or perpendicular to the journal.
Now a mitsu tech should know the difference between the two and should be able to figure out you had a diff pulley on it, whether he can prove it...probably not.
So far RRM makes good products for your car to go fast! bottom line. But I just don't like messing with the engine...exhaust and intake will probably come for me but as for a piggyback and other engine mods...im fine...I don't race it. Some others do.
This is my first new car and as a mechanic I know if you take care of it....it will last for a long long time...
