ROAD/RACE- Pulley 2008 Lancer
Old Nov 7, 2007 | 10:16 AM
  #301
Blacksheepdj's Avatar
Originally Posted by rontam90
has anyone had any problems with the pulley so far? interested in getting one
I have yet to hear a single complaint.
Old Nov 7, 2007 | 08:51 PM
  #302
ROCK's Avatar
No one that has one complains, that is for sure!
ROAD/RACE
Old Nov 8, 2007 | 02:14 AM
  #303
FinestSoldier's Avatar
I agree i intalled it and it was easy besides the instructions being wrong. but you def feel it. i have a manual so i guess i notice it more. I recommend it more then any of their other products.
Old Nov 8, 2007 | 11:56 AM
  #304
SeRious08's Avatar
I have a complaint -
Its way too easy to install
Its too cheap for the performance that it puts out
Its too light
LOL!
Old Nov 8, 2007 | 12:03 PM
  #305
elpoole's Avatar
I got a question. Does the Tension pulley shift when you loosen it or does it come off? The directions are not clear. I started to install myself and then realized if it comes completely off I might not be able to get it back on myself.
Clarification is needed.
Old Nov 8, 2007 | 12:10 PM
  #306
SamT83's Avatar
The pulley should shift positions (I think it's towards you if you're under the car) and the belt will loosen. If you're turning the bolt (unscrewing it), it will come off and that's wrong. You'll know the difference because it shifts a good amount.
Old Nov 8, 2007 | 12:11 PM
  #307
elpoole's Avatar
so do you need to loosen it at all or just push on it to give you the slack in order to get the belt off?
Old Nov 8, 2007 | 01:16 PM
  #308
SamT83's Avatar
Just push on it.
  #309
nj_08_gts's Avatar
Push on it and it will move. You will need a fairly long wrench to do it, is it takes a lot of leverage to move the tensioner
Old Nov 8, 2007 | 01:18 PM
  #310
elpoole's Avatar
You think an 18 volt impact wrench will get the factory pulley off?
Old Nov 8, 2007 | 01:35 PM
  #311
nj_08_gts's Avatar
Yep
Old Nov 8, 2007 | 01:38 PM
  #312
Well my electric wrench was able to after a couple of impacts. But the instructions due suck. if you go clockwise the screw starts coming off. you have to go counter-clockwise and you massive stregnth and the tensioner will bend toward you which will let you pull the belt off.
rather simple but you might need a hand. i recommend you get a friend to do the tensioner part so you have your hands to put the belt back on
Old Nov 8, 2007 | 01:42 PM
  #313
ROCK's Avatar
Yea don't take the pulley off. Just move it to release tension.
ROAD/RACE
Old Nov 8, 2007 | 01:54 PM
  #314
elpoole's Avatar
You say move it. I think you are really saying, push on it firmly is a Blank Direction to release tension of the belt. It should slide X amount which is enough to slip the belt off of the crank pulley.
Old Nov 8, 2007 | 02:01 PM
  #315
nj_08_gts's Avatar
Wouldn't you be able to SEE when the belt is loose enough to slip it off?
