spark plug wires problem...
Old Jul 1, 2007 | 01:06 PM
therzdae's Avatar
Okay, I just installed my spark plug wires, they are all put on correctly and snug... but its shakeing reallly bad, like if my lancer had a big block 402 in it thats the shake im getting... and no acceleration... whats the problem?!?!?
Old Jul 1, 2007 | 02:52 PM
therzdae's Avatar
any one?
Old Jul 1, 2007 | 03:07 PM
JohnnyBoy427's Avatar
I dont have much experience in this area but what if you got a fautly product. maybe throwing on your old wires and seeing if it still shakes would be a good idea.
Old Jul 1, 2007 | 03:37 PM
therzdae's Avatar
true, thanks man.
Old Jul 1, 2007 | 04:01 PM
therzdae's Avatar
put the stock back in, doin the same thing WTF
Old Jul 1, 2007 | 06:45 PM
02yellowozlance's Avatar
did you change the plugs
Old Jul 1, 2007 | 07:00 PM
therzdae's Avatar
i did like 200 miles ago, and didnt have problems
Old Jul 1, 2007 | 07:16 PM
i ran the problem through auto tech i am pretty sure you got the wires in the right order because there is only two wires so it says try some sea foam your fuel might have water in it or injectors clogged
Old Jul 1, 2007 | 11:40 PM
petey pab's Avatar
is your MAS unplugged? did you unplug the connectors on the coils?
Old Jul 2, 2007 | 04:36 AM
therzdae's Avatar
wtf is a MAS... and yes i unpluged the connectors but plugged them back...
Old Jul 2, 2007 | 07:59 AM
atilla's Avatar
MAS = mass airflow sensor.
sounds like it very well could be a vacuum leak... if you did the plugs 200 miles ago that's just strange that they'd cause a problem now. pull them out, check the gap and stick them back in. what brand and type did you use btw?
a easy way to check vacuum lines is to spray carb cleaner on the item you think you have a leak from. if you have a leak the car will rev up since it will suck in the carb cleaner which is combustible.
my car ran like this when i had a vacuum leak. not sure how i did it, but i broke the hose that travels from my FPR on my fuel rail to the intake manifold. check any smaller hoses like that which could have just degraded and cracked over time.
Old Jul 2, 2007 | 11:18 AM
therzdae's Avatar
but why would they be acting up when i took the plugs out? grr.
Old Jul 2, 2007 | 01:12 PM
kungfugirl's Avatar
go back and check ALL connections even close to wire install, did you touch anything else? not having a tube connected right could be an issue. check all vacuum.
Old Jul 3, 2007 | 11:25 AM
therzdae's Avatar
Alright, I spent all yesturday on it and ended up one of the wire head things were blown.... the lil black console thing on top
Old Jul 3, 2007 | 11:59 AM
atilla's Avatar
the coil pack?
