100k miles on lancer
Old Dec 23, 2007 | 08:54 AM
  #46
Domanni82's Avatar
59784 miles........60000 comming next week.....DArn timing belt replacement time commin'. "I dont wanna replace it." I definately need to get some new shop equipment. Dont wanna have to take it to a mech. but.......... looks like thats my only option. Other than that still kikkin strong and drive it like i stole it every day. Probally should calm down a lil. but its still a fun car to drive...
Old Dec 26, 2007 | 09:27 AM
  #47
mauisurf2003's Avatar
i'm at 107,000 now and my power steering pump has taken a crap but its still running great just reg. maintenance yadadimeng oh yeah but i gotta get a compression test cause my engine is eatting oil
Old Jan 3, 2008 | 02:16 PM
  #48
wc2k7's Avatar
107,000 on mine got it at 79 k. Regular oil changes and shes been running good except for this code i got which i think its the o2 sensor. Only thing that went out on me was my battery in the walmart parking lot.
Old Jan 27, 2008 | 11:01 PM
  #49
pinOyZ's Avatar
almost 110k on my 03 oz rally. still kicking! aem cold air intake, greddy evo2 catback exhuast system. short shifter. thats it.
Old Jan 27, 2008 | 11:04 PM
  #50
pinOyZ's Avatar
just do the maintenance and everything will be fine!
Old Feb 17, 2008 | 06:37 PM
  #51
itscypha's Avatar
yea just do the maint...like said and you'll be fine...luckily i only have 57k.
Old Feb 17, 2008 | 10:33 PM
  #52
mstkenny04's Avatar
ehh.. worthless.. o wellzz lol... 95k on mine
Old Feb 17, 2008 | 11:08 PM
  #53
Frankracer88's Avatar
im @ 103000 and im turbo.
Shes still running strong.
havnt really had any problems but im guna do a timing belt soon and i need to get a new turbo cuz im pretty sure i blew the oil seal on mine.
Old Feb 18, 2008 | 07:36 PM
  #54
miada lancer's Avatar
about to hit 111k, everythings running good so far. need a tranny flush soon though, and i have a SEL that comes on and off every so often, its for the warm-up cat in the exhaust manifold, other then that, regularly maintain it and she'll last quite some time..
^^ and if u havent done the timing belt and water pump by now its def wise to get er done. especially if youre close to 100k.
Old Feb 27, 2008 | 04:34 PM
  #55
Dreamartist's Avatar
111,xxx for me. Running fairly decent. Timing belt time is coming soon. Anyone know when it's time to change a water pump? I had mine changed 50,xxx miles ago.
Old Mar 2, 2008 | 11:28 PM
  #56
pinOyZ's Avatar
Just Follow The Maintenance Service And Everything Will Be Fine!
Old Mar 3, 2008 | 12:18 AM
  #57
ThunderOZ's Avatar
I changed mine when I did the timing belt...Around 100k miles...
Old Mar 11, 2008 | 01:22 PM
  #58
fe2o3's Avatar
75,000 All I've done is brake pads, brake pads, and brake pads.
Speaking of them becoming worthless, I bought used with 46,000 because they go worthless so fast! High depreciation is always looked at negatively, but use it to your advantage when you are buying used.
Old Mar 11, 2008 | 03:59 PM
  #59
apexlancer02's Avatar
my 02 has 75,000 and ive had no problems just the routine maint. the timing belt was pretty easy to change and other then that brakes take me about 20 minutes flat now.
Old Mar 31, 2008 | 11:02 AM
  #60
jwick76's Avatar
90k here, baby
Only issues I've had with my 2003 OZ was the sunroof, catalytic converter (recall issue), and the rear brakes. The sunroof had to be adjusted 3 different times during the first year, it would stick open, it would grind, etc. Just had to put some lockthread on the bolts....but now it sits about 1/4" lower than the roof profile. *shrugs*
The catalytic converter was a recall deal, engine light came on and I brought it in to see what was what...5 hours later, had a new converter...free.
Rear brakes, for some reason they didn't wear more than a fraction of what they should, and I was burning through front pads at a rate of about 20k. I finally replaced the rear drums and put in some ceramics...found that the brakes don't auto-adjust, and that after the first 10k or so weren't gripping at ALL. I still had pristine stock drums and barely any brake wear... Found the wheel cylinders are about to go (just did this yesterday). WORD TO THE WISE: If you can afford it, get a drum to disk conversion kit for the rear brakes, the drum/shoe setup is a !#@# to do, especially without a spring retainer tool....took me all day! Brakes work awesome now, so you might want to check these every 10-15k if you notice your front brakes doing all the work...
Planning on hitting 200k with this puppy
