100k miles on lancer
Old Aug 18, 2010 | 09:12 AM
  #91
jsdragonsoul333's Avatar
My 06 just turned 60K. She's just barely broken in. . Really, if you take care of the car and do all appropriate maintenance I don't see why these little econo-boxes won't last for a very long time. The Lancer Carpet is kind of crappy and you have to watch minor things like weather stripping/door seal stripping but mechanically they are pretty good.
Old Aug 23, 2010 | 06:10 AM
  #92
RDSSPIEGEL's Avatar
2003 oz
132K still runs Great!.... only thing acting up is the Trans.. but thats only because i abuse it but its still the same one.... only thing i had to change has been some head gasket seals!
Old Sep 6, 2010 | 09:06 AM
  #93
davesracecar's Avatar
im at 126k. just replaced my t-belt , waterpump, valve cover gaskets w/ sparkplug ring gaskets, drive belts, a worn outer tierod end and some worn bushings + alignment , luckly i did all repairs myself and saved hundreds. its true some cars hold up better than others. but as long as you take care of the vehicle, it will last for ages. probly one of the best purchases ive made was buying snow tires. If you're gunna drived the car, might as well take care of the car.
Old Sep 9, 2010 | 11:50 AM
  #94
davidmitsusrock's Avatar
Originally Posted by jforward5
My old stock 2002 Lancer OZ engine had 182k on it and started detonating. So I swapped it for somethin better.
I like your style . That's what I want to do with my car if the engine ever craps on me, 4g64 time! 112k now and still running strong.
Old Sep 9, 2010 | 01:32 PM
  #95
Mitsu.kid.02's Avatar
Mine hit 130k, instead of a regular tune up, i went turbo (this weekend)
Old Sep 9, 2010 | 09:02 PM
  #96
HornstarBU's Avatar
dang sun! 130k is no joke, I'm a little scared of the turbo project and I'm half that. So, by "instead of a tune up" what are you not doing, changing the timing belt/water pump? are you not doing anything that you should be because you spent money on the turbo, because I hear that's like, a recipe for disaster. With a turbo car, you're supposed to do double the maintenance and really make her feel special!
Old Sep 10, 2010 | 03:51 AM
  #97
Well i do take very good care of my bby It had the timing tune up about 35k ago so thats set, today i start the turbo install right when i get out of work, for the turbo goes in new plugs, my NGK wires, new fresh oil change of course because the pan comes off, new air filter for the turbo intake, and filled up with 93 octane So the car is getting a regular maintanance tune up, but with that comes a super tune up via turbo! haha
Old Sep 10, 2010 | 02:13 PM
  #98
Did you do a compression test or anything before you went boost? How many lbs are you going to run? I see these guys with high mileage boosting and I have yet to see a problem...makes me want to start putting together a kit.
Old Sep 10, 2010 | 02:37 PM
  #99
HornstarBU's Avatar
haha, nice. Good luck on that thing! Mine's nearing install day, not quite though. I'm slow as a turtle, and being way too cautious about it.
Old Sep 13, 2010 | 09:33 AM
  #100
Yeah but its good to be cautious!! Im finished! took about 9 hours to do!! I love the boost its so much more pull even at like 2 psi its amazing!
Old Sep 13, 2010 | 09:47 AM
  #101
kmcconn9's Avatar
80k on mine, doing front brakes, tranny filter and fluid (auto), plugs, cabin and intake filter and oil change...runs fine for a beater...
Old Sep 13, 2010 | 10:20 AM
  #102
No compression test, but the car runs great now, and was running fine before turbo..when we dropped the pan you can see the cylinder walls and they were mint, no scratches or dull spots they were like glass Im only hitting 3 PSI right now i think i have a vac leak somewhere, i need to do a boost leak test, but i want to run 5 right now! Even at 3 its really so much of a noticable increese in power! You really should start to put a kit together, run like 5 PSI, let me tell you its so addicting!!!
Old Sep 13, 2010 | 12:04 PM
  #103
Seifer780's Avatar
02 OZ Rally and at 162,500 time for a Bosch Premium oil filter and Valvoline Synpower 5W30 FTW
Old Sep 13, 2010 | 04:02 PM
  #104
HornstarBU's Avatar
/me prays no one starts the synthetic vs conventional arguement...
Old Sep 15, 2010 | 10:16 AM
  #105
Seifer780's Avatar
I say to each their own.
Of course no one will settle for that......but there we are.
