RRM Pistons and Rods
Old Sep 5, 2007 | 04:53 PM
redstar56785's Avatar
Hey guys,
I caught some water the other day and need a new rod. I was thinking since Mitsu has already got my **** apart I might as well install RRM rods and pistons instead of paying for the labor later.m If I'm slightly modded planning on going Turbo soon, would I need to do anything to my car when I installed the RRM rtods and pistons?
Thanks guys
Old Sep 5, 2007 | 05:22 PM
ambystom01's Avatar
I don't think so.
Old Sep 5, 2007 | 06:39 PM
SLVROZ_03's Avatar
Only thing I can think of is block related...any scarring on the cyl wall? How many miles on the block?
Old Sep 5, 2007 | 06:47 PM
ambystom01's Avatar
I've heard you need to modify the block slightly to fit the rods but a machine shop should be able to do it when they install the rods and pistons.
Old Sep 5, 2007 | 07:11 PM
No damage to the cylinders, i just got a semi-banana conrod. Im gonna have Mitsu install them though. My mitsu isnt completely evil i hope :P
Old Sep 6, 2007 | 01:41 PM
senate6268's Avatar
Yea. The block needs to be notched on either side of each cylinder to allow for travel on the Pauter rods. Crower rods don't need any modifications done to the block to fit. Drop in and go.
Old Sep 6, 2007 | 01:47 PM
lancerrally45's Avatar
who sells the crower rods for the cheapest?
Old Sep 6, 2007 | 01:49 PM
senate6268's Avatar
I don't really think there are any vendors selling the Crower rods. You can get them directly from Crower for like $720 or so.
Old Sep 6, 2007 | 05:25 PM
SLVROZ_03's Avatar
^Ouch
Old Sep 6, 2007 | 05:26 PM
ambystom01's Avatar
Gotta pay to play.
Old Sep 6, 2007 | 05:28 PM
Evodreamer28's Avatar
Those crower rods arent that expensive considering that rrm charges $799. Which makes them a bit cheaper to get the crowed rods. I dont understand though if the pauter rods are made for our vehicles why you would have to notch anything.
Old Sep 6, 2007 | 05:30 PM
mitsuozboi's Avatar
yeh. the whole notching things is odd.... Usually rods just drop in.... now if you go with a bigger piston I understand having to do work.
Old Sep 7, 2007 | 11:33 AM
senate6268's Avatar
You have to notch the block because the Pauter rods were made too wide on the beam. But because of this, they are a little stronger than Crower. They hit the very bottom of the cylinder walls on upstroke and downstroke without notching both sides at the bottom of the cylinders. Compare Crower rods and Pauter rods and you'll notice the difference in the width of the rod beam.
Old Sep 7, 2007 | 11:43 AM
ambystom01's Avatar
Something tells me that Crower rods would be more than adequate for any lancers needs.
sgambino92
Oct 31, 2015 11:36 PM
03oztim
02-03 Lancer Show / Shine
Oct 26, 2010 09:12 PM
Megadeth2118
Lancer Aftermarket Forced Induction Tech
17
Oct 7, 2004 03:07 PM
lancerozr
Lancer Engine Tech
15
Jun 2, 2004 10:09 PM
NITROHEAD
Jan 3, 2004 11:34 PM
