what spark plugs???
Old Sep 12, 2007 | 09:13 PM
NOTORIOUSLANCER's Avatar
what spark plugs???
I dont wanna get the autozone spark plugs an wires, what are other options i can use on a 02 lancer es. An where can i get them
Old Sep 12, 2007 | 09:16 PM
Evodreamer28's Avatar
I would suggest checking out www.speedcorps.com , They have ngk iridiums and ngk spark plug wires at a very good price.
http://stores.speedcorps.com/Detail.bok?no=196 Plugs
http://stores.speedcorps.com/Detail.bok?no=225 Wires
Old Sep 12, 2007 | 09:21 PM
Blacksheepdj's Avatar
Amen to that.
NGK plug wires are the best deal ($20-25)
I honestly think the type of plug doesn't matter. You can run whatever you want; the car will run the same no matter what.
Old Sep 12, 2007 | 09:22 PM
ahhhh thanks
Old Sep 12, 2007 | 09:25 PM
By getting this that be all ill need right.... but what the Coil Wire that is not Included
Old Sep 12, 2007 | 09:29 PM
Yes that would be all you would need. The "coil wires" they talk about are actually the coil packs, so unless those are bad their is no need to replace them. They normally dont go bad. Its just the wires and plugs you want to replace.
Old Sep 12, 2007 | 09:32 PM
thanks for the help man
Old Sep 12, 2007 | 09:35 PM
Not a problem!!!
Old Sep 13, 2007 | 10:30 AM
iufan4lifeul's Avatar
No need for those expensive plugs. Get the NGK wires... Best deal on those. Get the copper core plugs from NGK. They are called V-power. Better spark, smoother idle. and $1.50 a pop
Old Sep 13, 2007 | 01:03 PM
nawgee's Avatar
amen to that...copper core plugs would get the job done as well
Old Sep 13, 2007 | 02:35 PM
where can i get those NGK copper core for 1.50 found a site they have them for 3.25
Old Sep 13, 2007 | 02:41 PM
moreryce's Avatar
find the code of the plug you need/want and go to napa or autozone or checker or kregan..
Old Sep 13, 2007 | 06:50 PM
napa, autozone, oreilly, anywhere. Copper plugs FTW.
Old Sep 13, 2007 | 06:51 PM
Only disadvantage to copper plugs is they last only about 20k-25k miles but since they are SO EASY to replace that isn't a factor to me.
Old Sep 13, 2007 | 07:46 PM
is it bad to ride around with one bad spark plug for 2 weeks
