Custom CAI Fabrication!
Old Oct 6, 2007 | 01:07 AM
rmxusa's Avatar
Exclamation Custom CAI Fabrication!
Over the next few days I would like to get as many suggestions as possible as to what everyone here thinks about final placement of the filter, piping routes & anything else that does not damage any stock components or imped closing the hood.
The stock air filter box and tubing is going to be completely removed, a housing created for the MAS, and 3" diameter stainless steel 1/8" pipe will be used for this project.
I personally think I have already figured out the path for this which ends with the air filter in the low left fender right behind the open venting next to the fog light.
Once I've decided the final layout, It should take no longer then 3 days for me to finish the fabrication and be ready for me to test it.
Once this is completed and testing I'll be posting the steps it took and will also be willing to fabricate this assembly for other members on this site that are willing to pay for material costs upfront.
Lets get going!
Old Oct 6, 2007 | 02:03 AM
WangMan's Avatar
that's the path i've seen for all CAIs on a lancer. You don't want an "open" vent to the intake though imo because you don't want your filter getting wet. it will get plenty of cold air just sitting down there with the vent closed(stock)
Old Oct 6, 2007 | 06:06 AM
08LancerEVO's Avatar
i was thinking something like mounting it in between the bumper in the grill and route it up like the turbo on the evo will be.
https://www.evolutionm.net/forums/at...4&d=1190578170
like in between the radiator and the bumper where the main license plate is https://www.evolutionm.net/forums/at...4&d=1190578170
Old Oct 6, 2007 | 06:39 AM
Blacksheepdj's Avatar
Ever put your hand on the radiator? That'd quickly become a Hot Air Intake.
Old Oct 6, 2007 | 10:00 AM
rmxusa's Avatar
Agreed...I wont be putting this near the radiator for sure...Im going to start the prebuild right now! Ive got the piping i need and made the mounth to attach to the piping for the mass this morning at my shop.
Lets hear some more imput as i start doing the mach up ill be checking this thread as im tinking my tail/head lights aswell
Old Oct 6, 2007 | 11:34 AM
freebsdghost's Avatar
post photos as you work on it so we can see
Old Oct 6, 2007 | 01:02 PM
lmao, i see your point
Old Oct 6, 2007 | 01:31 PM
rmxusa's Avatar
I still havent been able to start welding but we have finished the prebuild now, I would take pictures but my fiance took my camera last night and wont be back till tomorrow so im going to hold off on anything else till tomorrow to ensure you guys have a full instructional thread to work off in the future...needless to say...with just the test tubing i saw i very nice boost on launch and my 80-100 was a good little jump in performance in 3rd gear...got up to 120 very easy i felt that with that being the only thing ive done to my car so far...and it not even being fully built that this car will start to shine on the street vs all cars in its class...si's are gonna be toast
Oh and after this project the full exhaust will be next...I love being able to custom fab my own ****
Old Oct 6, 2007 | 03:20 PM
that would be cool too! post info/how 2 on the exhaust as well
will it be a free flow exhaust or what?
Old Oct 6, 2007 | 03:26 PM
rmxusa's Avatar
That will be figured out over the next few weeks...that project is gonna take a little longer to tweak and gather ideas on then a simple CAI
Old Oct 6, 2007 | 03:56 PM
yea. well go as free as possible, and if you don't care for quiet that shouldn't be a problem!
take a look in summit for some free flow cats and flow through mufflers (if any at all ).
Old Oct 7, 2007 | 06:14 PM
rmxusa's Avatar
We finished the build for SAI seeing as we found no possible way of getting 3 inch piping into the side with the hood closing (the CAI i had planned on building)...the bat was the problem...but the other problem with the sai that we created is that now the car things my red line is 4K instead of 6.5K...so with that being said im kinda stumped...I tried letting the ecu figure it out and adapt as I saw in some other threads with previous lancers...but no luck there...so does anyone have a solution that doesnt require a dealers tuning touch?
Old Oct 7, 2007 | 08:30 PM
2008BLACKGTS's Avatar
Sounds like you are in safe mode...fix the MAFS and it will go back to an open loop.
Old Oct 7, 2007 | 09:43 PM
rmxusa's Avatar
fix the MAFS?...I dont see how it would have broke...anyone know anything else related to this problem??? Cause im really stumped and would rather not have to go to the dealership to find out the issue.
Old Oct 11, 2007 | 07:16 AM
gnnr's Avatar
MAFS, definately. It's obstructed, out of range, damaged, or not connected correctly. Unfortunately you can't fix out of range at the MAF, that's a ECU fix and from what RRM has said that looks to be not only tough, but requires probably more gear than you (or any one else here most likely) has on hand.
wickedep
May 10, 2017 03:18 PM
XSilverJ
80
Jan 30, 2016 07:37 AM
Jeffs2006EVOIX
11
May 29, 2008 09:33 PM
Archangelite
32
Mar 11, 2005 11:05 AM
