Urgent!
Old Oct 31, 2007 | 10:40 PM
MitsuOZ's Avatar
Exclamation Urgent!
a coilpack broke on me and it's stuck on the sparplug, and it seems like there's no way that i can think of to get it out, anyone with any advice?
Old Oct 31, 2007 | 10:57 PM
tookinkee's Avatar
where is it broke at...i used to be a mechanic....send me a pm with a pic and i might have an idea....seen wome weird stuff happen before..
Old Nov 1, 2007 | 09:38 AM
SLVROZ_03's Avatar
You need to pull on it harder! The only thing attached to the spark plug is the thin metal prong end of the boot. If the pack is indeed broken and in need of being replaced, it won't harm busting it up a bit. How did it "break" anyways?
Old Nov 1, 2007 | 01:36 PM
lancerrally45's Avatar
ill guess that the engine was hot causing the end of the spark plug to stick to the boot
Old Nov 1, 2007 | 02:27 PM
SLVROZ_03's Avatar
Usually, heat causes metal to contrat/expand. That's why it's not good to change plugs on a hot motor...btw, was your motor hot/warm when this happened?
Old Nov 2, 2007 | 08:29 AM
MitsuOZ's Avatar
well how it happened was the first time i pulled of the coild pack the coil inside moved. it went to the bottom insteadhow it's usually inside of it, then i wasn;t able to do it right away because soething cameup and i had to leave so i placed it back on, i drove aroun everything seemed fine althought the coild pack couldn;t go on, then i tried it again later but this time it came off eas but the wire from the inside is stuck on the spark plug, i ried pulling at it, and nothing.
Old Nov 2, 2007 | 08:40 AM
Punkskalar's Avatar
unbolt the valve cover, when its off you should be able to get a better grip on the coil pack...
Old Nov 2, 2007 | 01:40 PM
SLVROZ_03's Avatar
Only thing I can think of is using neddle-nose pliers and pull it off...? Any pics to show us exactly what you got there?
Old Nov 2, 2007 | 01:48 PM
MitsuOZ's Avatar
i'll post one up later on today, all you see it the ire sticking up, i tried needle nose pliers but i can;tgip it strong enough, maybe needle nose vise grips will do the trick
Old Nov 2, 2007 | 02:44 PM
crypto's Avatar
Former Vendor
i got one of the suction thingys from a socket set stuck on a plug once. I ended up using needle nose pliers holding a set of my wifes tweezers to get down in there and pull it off
Old Nov 2, 2007 | 03:56 PM
SLVROZ_03's Avatar
Fixed!
