Po421
Old Feb 25, 2008 | 06:33 AM
02-Lancer-Es's Avatar
yup code never came back
thanx guys
Old Feb 25, 2008 | 07:09 AM
atilla's Avatar
glad it worked. those things are magic, eh?
Old Feb 25, 2008 | 10:28 AM
Evo666's Avatar
Good to hear it worked for ya.
Old Feb 26, 2008 | 07:08 AM
Jehuty's Avatar
What is this fouler trick, can someone send me link to forum about this please.
Old Mar 4, 2008 | 04:25 PM
Synthrocker's Avatar
You can gut out both your cats and run them like that all day, thought your CEL will be on at all times and you will be in open loop- uses set limits to run the engine, no compensation- and its illegal, though I ran without a cat in my VW for about a year and a half ^_^ I gutted it out myself.
An O2 sensor works by measuring the oxygen in the exhaust and thats all, it does not measures, nor see's ANYother gas. When it see's a huge difference it sets a CEL and tells the computer to go into open loop.
What the fouler or CEL elimter does is puts more space between the exhaust and the sensor, so the sensor will see the right amount of oxygen, and hopefully tricks it into reading normal, this is why it sometimes works and sometimes does not.
Old Mar 24, 2008 | 08:26 PM
shinbumee's Avatar
one more question about fouler's trick..
so.. to do the fouler's trick, all I have to is just take off the 2nd o2 sensor? The one under the car?
Old Mar 24, 2008 | 08:41 PM
Evo666's Avatar
Yes you must take off the 2nd o2 then add the anti-fouler
Old Mar 24, 2008 | 09:34 PM
drucea's Avatar
The only cat you really need is one before the second o2 sensor. The first sensor reads the air straight out of the engine. you could have a straight pipe from the header to the muffler, as long as you have an o2 compliant cat before your second o2 sensor. That's how mine is set up. Just buy a $60 high flow magnaflow cat, put it before your second o2 sensor, and you'll have no CEL.
Old Sep 24, 2009 | 09:47 PM
Ketchup2me's Avatar
Hey i bought my car with 76k and i swear around 80k my CEL came on with the p0421 code. i have the obd 2 scanner so i've memorized this code by now. It never affected anythign but now i have 96k miles and i'm due for a inspection sticker soon.
Old Oct 6, 2009 | 11:19 AM
drucea's Avatar
It's still the catalyst efficiancy below threshold right? Either try a $15 CEL eliminator trick or get a new cat probably. One of those spark plug oil fouler eliminator things should work. Thats all the CEL eliminator lights are. But they're hit and miss but way cheaper to try out first
Old Oct 6, 2009 | 02:15 PM
ThunderOZ's Avatar
Do they mess with anything performance/gas mileage wise in the car? I always just clear them b/c I don't have any cats at all...
Old Oct 6, 2009 | 02:31 PM
darkmitsu's Avatar
one thing you can do is relocate the downstream o2 sensor behind the second cat... Drill a hole , weld a bung in place , and extend the wiring for the rear / downstream o2 ... Our cars have 2 cat converters one in the exhaust manifold and one where every other car has em about midway thru the exhaust system, the rear / downstream o2 is really only testing the efficiency of the exhaust manifold cat and not the mid-cat... So if you want after placing the rear o2 sensor were it is suppose to go you can take off the downpipe take a long screwdriver and a hammer and gut the exhaust manifold cat.
Old Oct 7, 2009 | 03:17 AM
Jehuty's Avatar
CAnt' the evo ECU completely remove the need for the O2?
Old Oct 7, 2009 | 07:13 AM
ThunderOZ's Avatar
Tephra mod. I don't see why we can't do it too...
Old Oct 7, 2009 | 07:19 AM
Jehuty's Avatar
Good because I have a high flow cat and I put in a CEL eliminator and I STILL have the code.
lancerchk_oz
Lancer Engine Tech
10
Apr 21, 2011 03:19 PM
inariv5573
23
Nov 16, 2009 02:20 PM
commandwolf
Oct 26, 2009 07:53 AM
wek
Feb 27, 2008 07:01 AM
diesel_fan
Lancer Engine Tech
Nov 22, 2002 07:26 AM
