Rrm headers with check engine light
Old Apr 9, 2011 | 08:59 AM
lancerchk_oz's Avatar
So I professionally installed the rrm headers into my 02 lancer oz and the check engine light comes on with a code basically stating the cat converter has been deleted I have also installed the cel eliminator but still cel comes on anyone have any suggestions? Please help! thanks for your time
Old Apr 9, 2011 | 10:39 AM
mci2727's Avatar
Which O2 did you put the cel eliminator on?
Put one on each O2 sensor and that should take care of it.
Old Apr 9, 2011 | 01:31 PM
ohh ok sounds good ill try that Thanks!
Old Apr 9, 2011 | 01:41 PM
slatermvp's Avatar
did you reset the ECU??
Old Apr 9, 2011 | 04:48 PM
jakermeister's Avatar
Usually goes on the 2nd cat
Old Apr 9, 2011 | 07:13 PM
mci2727's Avatar
Yes, for sure need to reset the cel to begin with.
I assume you've already done this but if not unhook the battery for 30 min and then hook it back up.
Start your car and let it idle for 20 min... drive around town and on interstate.
Will run rough at first.
Also it is true that putting a eliminator on the 2nd cat (under car) most of the time fixes this issue.
I just put one on each though and mine is fine.
Old Apr 10, 2011 | 02:14 PM
03lances's Avatar
I still have both my 02's and my wideband with a 3" straight pipe no cats. I have two sparkplug antifoulers on my 2nd 02 and the first is just threaded in like normal. I have never had a cel for the cat and its been a year and a half.
Old Apr 12, 2011 | 06:41 PM
sounds good guys i have the cel eliminator on the first o2 (coming off the headers) i reset the cel but only about 30 miles later it comes back on lol....so i will try to put the other cel eliminator on the second o2 ( the one under the car) i appreciate everyones help...lets see if this works! thanks a bunch everyone for your time and patience!
Old Apr 13, 2011 | 12:14 AM
03lances's Avatar
I recommend ONLY putting the eliminator on the 2nd 02 sensor, here is why.
You are getting the code because the 2nd 02 sensor is getting the same amount of exhaust "pollution" as the first one. The only reason we have the 2nd 02 is to monitor that the cat is doing its job by cleaning up alot of that pollution and sending cleaner exhaust past the 2nd 02 and on out the tail pipe. By putting the cel climinator on the second 02 sensor only this pulls the sensor out of the direct stream exhaust thus exposing it to less "pollution" and tricking the ecu into thinking the cat is working great since its getting the cleaner feedback from that 2nd 02. Having the eliminator on the 1st one just pulls it out of the direct stream too so if you take that off the first one it will go back down into the direct exhaust flow which will make it less likely for your cel to come back on.
Old Apr 13, 2011 | 05:29 PM
Awesome!! i will deff do that this weekend and see what happens thank you very much i will let you know how it turns out thanks again!
Old Apr 21, 2011 | 03:19 PM
just wanted to say thanks everyone for all your help!! switch the eliminator over and it worked so far so good!! thanks again!!
Silverfox742
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 12, 2008 10:28 AM
Master_French
20
Aug 25, 2006 11:55 AM
Ralliart Lancer
Lancer Troubleshooting
15
Feb 19, 2006 11:39 AM
Blacksheepdj
Lancer Engine Tech
41
Oct 17, 2004 06:59 PM
digdat
Lancer Engine Tech
Apr 1, 2004 12:43 PM
