4G96 cams
Old Jan 31, 2008 | 05:33 PM
gaga123's Avatar
Smile 4G96 cams
any 1 can advise on getting cams for my auto 4g94? i was thinking of getting a 262 cam for it... bear in mind thats its auto and stock...
Old Jan 31, 2008 | 05:47 PM
ambystom01's Avatar
I would suggest you read the FAQ in my sig, it will help answer this question.
Old Jan 31, 2008 | 10:55 PM
gaga123's Avatar
i get that the timing shouldn't be too high or it'll spoil the engine... but will it help if i get adjustable cam gears? i want the pick up to be a little better and lighter... thanks
for the help....
Old Jan 31, 2008 | 11:00 PM
ambystom01's Avatar
Read the FAQ thoroughly, I spent a lot of time writing the cam section specifically for this reason. Basically, a cam is useless on a stock motor.
Old Feb 1, 2008 | 12:56 AM
gaga123's Avatar
i totally get it now... but i heard raising the degrees a little will help... i might be wrong...
Old Feb 1, 2008 | 01:33 AM
Lumpy's Avatar
It'd be cheaper and less invasive (or risky) to just change the crank pulley to a lighter weight one. Pickup is better and lighter without having to open anything more than a little wheel well plastic.
Old Feb 1, 2008 | 10:24 AM
gaga123's Avatar
well... i guess thats out of the question than.. i dont wanna blow anything... i think i'll just go with a safc and adjust it so that it''' flood the chamber at hightr rpm's... that'll probably work... any one know any setting for that ? ratios and links would be grately appreciated...
Old Feb 1, 2008 | 10:48 AM
ambystom01's Avatar
What are you talking about? Flood the chamber with what, gas? I would strongly suggest you learn more about tuning before you actually do it.
Pale Horse
Jun 16, 2014 01:16 PM
4G63 T
Oct 13, 2012 08:20 PM
jacfumo
Nov 23, 2008 01:33 AM
Noe18
37
Jan 10, 2008 12:09 PM
Noe18
Jan 2, 2008 06:00 PM
