cam gear ajustement, how to ajust
Old Feb 10, 2008 | 03:55 PM
billylancer's Avatar
I just purchase a fidenza cam gear and i dont know how to set it up right
any wonder how to get the best of it
injen C.A.I
chicara headers (fit in)
fidenza flyweel
fidenza short throw
centerforce dual friction clutch
light weight 16 inch weels
FALKEN tires
american racing strut bars
T.Y.C lights
ractive steering
who care shifter ball
and plenty of other crap
4g94 stock engine
Old Feb 10, 2008 | 04:01 PM
sorry for the wrong thread forum a im not good at it
will you ever forgive me?
the rookie
Old Feb 10, 2008 | 04:40 PM
SLVROZ_03's Avatar
Set the timing degree @ 0, then when you go to a dyno have them fool with it.
Old Feb 10, 2008 | 04:47 PM
ambystom01's Avatar
Based on the mods, I don't think there's a lot that can be done. You only have two engine mods and they're mild ones at that. I would wait until you have more mods (like a more aggressive camshaft, ported head, turbo, etc.) until you change the timing since right now, you're basically stock.
Old Feb 10, 2008 | 04:49 PM
so i cant do this at home?
i did all of the worck my self i im not that bad in mecanic
Old Feb 10, 2008 | 06:20 PM
SLVROZ_03's Avatar
No, you can install yourself...but to get any gains from it would be only figured out via a tuner. Keep the cam timed @ 0 degrees and install with the stock timing @ TDC.
Old Feb 10, 2008 | 11:11 PM
CityKnight's Avatar
I have a Fidanza Adj. Cam-Gear.
Retard the Timing 3° (Max) and you'll have more Low-End TQ.
Your idle will be abit rougher however.
Nothing too bad, but you'll notice the difference.
If you Advance it, you'll have more Top-End HP.
I wouldnt go beyond 3° however, you may hurt your engine.
I played with it and tested each setting, one by one, each way (+/-).
Test it out and see what you like.
Its nothing HUGE, but it is a recognizable difference.
Remembe to disconnect the batttery for a few minutes to reset the ECU each time you make a change.
Old Feb 11, 2008 | 12:49 PM
thanks for the info. i will come back with the result
it's play time!
Old Feb 22, 2008 | 02:05 PM
The result is mostly as predicted, I gained a little power. The next step is to turbo my car. The kit is purchase and I'm waiting for delivery. It is supposed to take 2 weeks.
Last edited by ambystom01; Feb 22, 2008 at 02:15 PM. Reason: fixed grammar/spelling
Old Feb 22, 2008 | 02:14 PM
ambystom01's Avatar
Sorry, I'm just gonna edit that cause my brain hurts.
Old Feb 22, 2008 | 04:39 PM
did it make you feel better?
Old Feb 23, 2008 | 01:20 PM
ambystom01's Avatar
It made the post easier to read for other people, so yes.
Old Feb 23, 2008 | 02:18 PM
at least someone is posting some thing here
that smells!
Old Feb 23, 2008 | 03:31 PM
ambystom01's Avatar
What?
Old Feb 23, 2008 | 03:43 PM
exactly sir
