Anyone using nitrous?
Old Feb 13, 2008 | 03:46 PM
06BlackES's Avatar
Question Anyone using nitrous?
I was wondering if anyone is running NOS, how is the car holding up, and what size/setup they have?
Old Feb 13, 2008 | 05:16 PM
Khoranic's Avatar
yes this is also a topic i am very curious about. I really want the RRM turbo kit when released... but i may try to go as far as possible N/A First...
Old Feb 13, 2008 | 07:16 PM
Blacksheepdj's Avatar
And this is in the Turbo forum . . . why?
Moving.
PS - it's nitrous. NOS is a brand.
Old Feb 13, 2008 | 07:31 PM
bigstott's Avatar
umm you could probubly do a small shot of Nitrous 55-75 HP worth and be fine i believe the motor will handle it without a problem
Old Feb 13, 2008 | 08:18 PM
KBkilla0006's Avatar
be aware your engine life will decrease...
Old Feb 13, 2008 | 08:39 PM
08LancerEVO's Avatar
some one here has. i saw it in his sig.
with the manual. i think you can run maby a 50 shot of NITROUS... ricers call it NOS.
if you have a cvt, forgettaboutit
Old Feb 13, 2008 | 08:56 PM
06BlackES's Avatar
i was wondering if anyone was using NOS, that brand name, a buddy of mine wants to sell his and i was asking if anyone is using this particular brand...sorry for the confusion
Old Feb 13, 2008 | 09:05 PM
ambystom01's Avatar
Which kit you run isn't exactly a useful question since all nitrous kits are more or less made equal whether it's NOS, ZEX or whatever. I would personally recommend not running nitrous as the last gen engine was known to respond very poorly to it (ie. destroyed pistons/rods). If you have the money to deal with those problems though, go nuts. If you're going to do it, for the love of god get a wet kit.
Old Feb 13, 2008 | 09:11 PM
krnkimchi702's Avatar
could you explain the differences between a wet shot and a dry shot??
Old Feb 13, 2008 | 09:17 PM
otter's Avatar
EvoM Administrator
Dry shot = just nitrous spray
Wet shot = nitrous and fuel spray
I don't think you guys are giving this engine enough credit. This isn't the weak 4G94. IIRC, the 4B11 has forged rods. I'm willing to bet, with a proper tune and wet setup, that a 100 shot can safely be run. I'm basing that on what the 4G69 can run, which IMO has more in common with the 4B11 than the 4G94 did.
Old Feb 13, 2008 | 09:25 PM
ambystom01's Avatar
Otter covered it nicely, wet just means fuel is added at the same time which is far safer. I don't think a 100 shot is realistic, 50 or 75 maybe but a 100 shot is a pretty big stress on the motor. We won't actually know until someone does it though.
Old Feb 14, 2008 | 06:51 AM
SeRious08's Avatar
A 50 shot is a safe shot without having any tuning done. If you bump up to a 75 shot, you will need to start looking into removing some spark timing.
I have a wet kit but I havn't installed it yet. I still waiting to figure out which wire on the throttle body is the WOT. I have a electronic activation switch (TPS) that has to be wired into it. I called Brian with RRM and he said that he was looking into it.
Old Feb 14, 2008 | 08:51 AM
06BlackES's Avatar
let me know how it works out for you, i also think a 50 shot would be fine as long as you dont use it every time you drive.
Old Feb 14, 2008 | 02:08 PM
exactly. its all basically the same. what matters is wats in the bottle.
finnsweetheart
Midwest Region
41
Aug 27, 2008 04:43 PM
93civEJ1
Jul 8, 2005 07:19 AM
bolsen
Feb 1, 2005 08:16 PM
03cobra
Northwest Region
12
Mar 4, 2004 01:07 AM
