rod bearing? piston rings?
Old Feb 21, 2008 | 10:45 AM
*Zero*'s Avatar
which should I use? i was thinking of getting some rods and pistons from Speed Corps but didnt see any aftermarket bearing or rings....
could I still use stock ones or is there some recommended ones to use for aftermarket apps.?
Old Feb 21, 2008 | 11:47 AM
ambystom01's Avatar
Just use the stock bearings but obviously get new ones. The pistons should come with rings.
Old Feb 21, 2008 | 11:52 AM
lancer2show's Avatar
are you boosting?
cincy's Avatar
just make sure you also have the cylinders honed before installing new pistons and rings. If not, your compression will suck
Old Feb 21, 2008 | 12:20 PM
*Zero*'s Avatar
ok thanks.... i've rebult bottom ends for hondas and they have aftermarket rings and bearings so i didnt know if anyone made some for lancers
Originally Posted by lancer2show
are you boosting?
no boost right away....just want to build the bottom end for now to prep for boost down the road....
thanks for the info....
ill have it done as soon as i swap the pistions out.....i might have the crank mirco polished as well while im at it....honda's to me are so much easier to build lol
Old Feb 21, 2008 | 01:22 PM
SLVROZ_03's Avatar
^Hondas just seem to be easier cuz they've been out since the dawn of time! and have a MUCH larger aftermarket.
What exactly is your experience in anyways? I'm building a 1.6L for boost as we speak!
Old Feb 21, 2008 | 01:34 PM
*Zero*'s Avatar
in a honda?
lets see....i've built b series from the ground up,d series, currently builting a ZC for the wife's drag crx....i've owned many many hondas....a little too many...rebuilt bottom ends and some minor head work here and there....the zc im doing now is going to have a fully built bottom end with a micro polish crank,high compression pistons,full port and polish head,3 angle valve job, most likely skunk 2 internals on the head and maybe boost down the road....
might even push a small shot of juice through the motor...my first zc was in a 88 HF fully gutted with a 6 puck un sprung with a lightin flywheel...cheap header and intake with stock cams and internals....on slicks and a 50 shot, ran a 13.55 in a 1/4....i've done my share but trying to move on to something different cause honda's are very over rated here in AZ with the whole "if it isnt JDM, you aint ****!!!"
BKGTS22
Jun 12, 2016 01:50 PM
alexeiyreina
Oct 11, 2013 06:29 AM
workel2man911
Mar 10, 2011 05:17 PM
Evo VIII 4G63
Jan 18, 2007 10:49 AM
bishiboy
11
Nov 26, 2004 03:48 PM
