Removing cat= HP gains? EVOX parts on LancerX?
Old Mar 4, 2008 | 10:32 PM
katafuji's Avatar
would removing the cat on our cars give us more HP? Also, would cat-back and test pipe for EVOX fit on the 08 lancer?
Old Mar 4, 2008 | 10:52 PM
CamShaft's Avatar
if you remove the cat, you will get a check engine light. Unless you know or have the product to simulate an o2 sensor varying voltage.
Old Mar 6, 2008 | 08:36 AM
Blacksheepdj's Avatar
Removing the cat will probably put the car in LIMP mode (exactly what it sounds like) because of the CEL. As CamShaft said, you'd need a workaround.
Also, you'd probably lose all of your lowend torque. Your car would feel like a snail when taking off from a stop. But it would probably go like a cheetah at high-RPM driving.
Evo parts will not fit. Because of the turbo, their exhaust is very different from the Lancer DE/ES/GTS exhaust.
Old Mar 6, 2008 | 01:53 PM
Jamie@WORKS's Avatar
Not only that, but the layout is a bit different. That tunnel that provides a nice passageway for the Lancer exhaust is filled with a drive shaft in the EVO and the exhaust gets pushed aside. You'd need custom brackets, etc.. in addition to the different routing and flange locations for it all to go together. Oh, and you'd need to cut a hole in the bumper cover to account for the extra outlet pipe
That cat removal would allow more flow up top, but could bite into your torque down low.
Old Mar 6, 2008 | 07:02 PM
katafuji's Avatar
so what about hi-flow cats? i guess putting one on the lancer would be better than going catless right?
Old Mar 7, 2008 | 08:58 AM
Yeah, but it's also a HUGE waste of time. If you're putting an HFC on a N/A car, you're basically wasting time and money to gain zero HP. If you're putting an HFC on a turbo car, you're basically replacing an airflow restriction with a different airflow restriction.
HFC is basically a mod where you say "I've done everything else possible, and I want to do something to the catalytic converter, but I want my car to stay legal and environmentally-friendly." It should be the LAST part you purchase.
Old Mar 7, 2008 | 09:35 AM
nunyas's Avatar
not to mention that Cats tend to be one of the most expensive parts of your exhaust system.
Old Mar 7, 2008 | 10:03 AM
Or that it's completely illegal to remove/replace/alter it unless the stock one fails (and even then, you legally have to replace it with a certified unit that meets certain specs).
Old Mar 7, 2008 | 10:07 AM
nunyas's Avatar
yeah... that too... sometimes I wish I was still living in FL where they don't do inspections for stuff like that...
GFinley
Dec 10, 2015 09:26 PM
tscompusa
Evo X Dyno Results
15
Apr 29, 2013 01:56 PM
xDarKnighTx
Apr 11, 2012 07:33 AM
villero1834
Lancer Engine Tech
May 14, 2008 01:01 PM
Aby@MIL.SPEC
10
Dec 4, 2006 12:02 PM
