kamikazee with rrm turbo?
Old Aug 30, 2003 | 05:55 PM
lancer r us's Avatar
will kamikazee header work with the rrm turbo?
Old Aug 30, 2003 | 10:12 PM
pjal84's Avatar
If I recall, the Kamikaze header are long length runners like the RPW setup which removes the stock manifold/cat assembly so no, it would not work as Road Race's kit needs that stock assembly or their header to bolt up to the return pipe which feed the turbo.
Old Aug 30, 2003 | 10:20 PM
correct me if im wrong ok. having an up pipe to the turbo. vs. having a turbo manifold. would'nt it be better to have a turbo manifold. power is right away delivered to the turbo rather than it going up to the up pipe.
Old Aug 30, 2003 | 10:27 PM
J'sLancerLS's Avatar
Yo dude, get with Boe (Boeturbolancer) on this RRM turbo stuff... He's the King of that shiznit!
Old Aug 30, 2003 | 11:45 PM
blackmantis's Avatar
the boyz at rrm get plenty of power from the turbo feed up pipe plus the way it is set up with the stock header and cat it will be smog leagal in CA soon!!! but if ou have any tech questions deffinatly talk to Boe i can answer some of your questions but boe can answer all of them
Old Sep 2, 2003 | 08:06 AM
Guru_Del's Avatar
or if you have any questions on smog legality of it feel free to ask me.
Old Sep 2, 2003 | 08:15 AM
HobieKopek's Avatar
Yes, the up pipe is less efficient. No the Kamikaze header will not work without serious modification. At that point you may as well have an equal length manifold fabricated for optimal spooling.
Old Sep 4, 2003 | 12:18 PM
airlinevomitbag's Avatar
I had the same thought a while back. The flanges are different, 2 bolt RRM 3 bolt kamikaze. If you look at RRM's header it is a clone of the factory manifold as far as shape goes. The runners go down and to the right just a bit. The Kamikaze's all go to the middle which seriously makes it difficult to put piping for a up or down pipe on the left side next to the AC and both will not fit on the right side. Not to mention I do believe that Kamikaze comes out farther from the block too making it next to impossible to retain a Kamikaze header if you were to go turbo, it would have to be modified beyond recognition, I dont know about you but I dont like the thought of cutting up $260.
Old Sep 4, 2003 | 12:33 PM
cerfur's Avatar
from what i understand the only header options for the rrm are rrm itself or the rmr header witch would require some brakets being welded on but i dont know if the rmr header still exisits last i head the built 2 and only 2
sideway180sx
Jun 11, 2014 09:53 AM
sideway180sx
18
Jan 11, 2012 09:08 AM
sideway180sx
Evo X Dyno Results
27
Dec 5, 2010 07:31 AM
sideway180sx
Nov 20, 2010 01:38 PM
Sir Lancelot
Lancer Engine Tech
12
May 12, 2005 03:14 PM
