Head bolt torque specs and pattern
Old Jun 5, 2009 | 10:25 PM
imalancerman's Avatar
Hey all. Before anyone flames in case there is a post, I did use the search function albeit with the words that are in my heading and different combinations of them and couldnt find the info I wanted. Im looking for the torque specs for the head bolts and also the tightening pattern as well. Anyone know where I can get that without buying a 150 dollar manual from mitsu? Thank you.
Old Jun 6, 2009 | 05:39 AM
senate6268's Avatar
Here is the information you need.
Attached Thumbnails Head bolt torque specs and pattern-head.bolt.install.png
Old Jun 6, 2009 | 05:38 PM
Ok am I dumb or do other people not understand these instructions? When Ive done heads it usually goes one torque spec then another. Ive never had to make marks on the cylinder head before. Thats the only part I don't understand. Where do you make the marks on the cylinder head?
Old Jun 6, 2009 | 06:01 PM
senate6268's Avatar
They just want you to put a mark on the top of the bolt and a mark on the cylinder head right where the bolt goes into the hole like an indicator that both marks are lined up. That way you can tell when you've gone the additional 1/4 turn. Not really needed since you can just eyeball the additional 1/4 turn.
Old Jun 6, 2009 | 10:44 PM
Ah ok then. Thank you a ton senate. I just think its strange they don't do exact torque specs. just a 1/4 turn then another. I've never dealt with that putting heads on. They usually just give me an initial torque spec then another final torque spec.
RedGecko
Lancer Engine Tech
Sep 29, 2011 07:38 AM
usacchamp
Oct 19, 2010 01:30 AM
kaoscage
Jul 8, 2009 09:20 AM
fvaldes
Apr 15, 2009 09:50 AM
05silevo
Dec 29, 2006 07:37 PM
