Head torque pattern order???
Old Apr 13, 2009 | 10:53 AM
fvaldes's Avatar
Is there a specific patter for torquing the head or just the regular crossed procedure?
Old Apr 13, 2009 | 11:04 AM
JordanS4's Avatar
9 5 1 3 7
10 6 2 4 8
Old Apr 13, 2009 | 11:14 AM
fvaldes's Avatar
Originally Posted by JordanS4
9 5 1 3 7
10 6 2 4 8
Thanks for the info. I need to re torque them cause I got 110 130 115 120 reading on the cylinders and it is a brand new motor. I have been told that the normal numbers for compression should be around 220psi. with 8.5 - 1 pistons. Right?
Old Apr 13, 2009 | 12:25 PM
red evo8's Avatar
removal
install
Old Apr 13, 2009 | 12:39 PM
fvaldes's Avatar
Originally Posted by red evo8
removal
install
Thanks alot. This is very detailed. I should be ok now.
Old Apr 13, 2009 | 01:04 PM
Mr. Evo IX's Avatar
Compression numbers for a IX are not supposed to be around 220 psi, that would be a real high comression engine. Stock should be 145 psi with no more than 14psi difference between cylinders. The low limit is like 92 psi if they are even which seems ridiculous.
Old Apr 13, 2009 | 08:24 PM
fvaldes's Avatar
So, the compression numbers I get are normal, even for a new 2.3L motor? The pistons I have are 8.9 to 1.
Thanks for the info
Old Apr 15, 2009 | 09:50 AM
Mr. Evo IX's Avatar
110 is low in my opinion. Most of the IX's that we've tested are 135-150. Maybe your rings havent fully seated. How many miles are on the motor? When you compression tested were you WOT? Testing 1 cylinder at a time right (other 3 plugs should be in). Cold or Warm?
talonkev
May 14, 2017 11:16 AM
6466evo
23
Jun 23, 2015 09:29 PM
kmcconn9
Oct 8, 2009 06:38 AM
RallyGoneEvo
Jun 21, 2009 12:37 AM
ecuflasher
157
Mar 5, 2008 07:07 AM
