metal vibrating sound
Old Aug 13, 2009 | 10:09 PM
evolved 9's Avatar
need help please My Evo 9 Mr makes a vibrating metal like sound when just cruising and I push the gas
to the floor and give it load. Doesn't really matter wich gear I have it in. It doesn't do it all the the time , just once in a while. Dealor replaced ACD pump but noise is still their. Is there any one else that has had this problem? thanks in advance.
Old Aug 14, 2009 | 05:13 AM
EngRWW33's Avatar
might wanna check the EVO forums
Old Aug 14, 2009 | 07:58 AM
evolved 9's Avatar
I have, couldn't find any thing on this problem.
Old Aug 14, 2009 | 08:30 AM
Greedy_son's Avatar
Where is the sound coming from? under the car, under the hood or inside? Can you hear it when it idles?
I could be a rusted part that has fallen off and hitting another part. Exhaust shields are a common problem for this.
Old Aug 14, 2009 | 09:49 AM
evolved 9's Avatar
It's coming from under the car some where. I can feel it on my foot a little when I give the car full throttle. For example: if I'm going down a street doing 35ish in fourth gear and push the gas to the floor I hear the noise . It's almost like a buzzing sound. could it be the transfer case?
Old Aug 14, 2009 | 09:50 AM
evolved 9's Avatar
Don't here it when it idles.
Old Aug 14, 2009 | 12:22 PM
MasterAK's Avatar
do the motor mounts look ok?
Old Aug 14, 2009 | 02:49 PM
evolved 9's Avatar
yes !
Old Aug 21, 2009 | 07:02 PM
evo 8 ya's Avatar
Just so happends I'm in the Lancer forums researching a GTS for my girl. Anyway, if your exhaust is stock... check the heat shields. If it has a upgraded exhaust... check the downpipe and see if it's rattling against the cross brace.
Simko
Oct 4, 2016 11:39 AM
thejoshster
Aug 25, 2012 11:33 AM
fishie36
May 25, 2010 06:56 PM
m0nkie
12
May 2, 2010 06:03 PM
inariv5573
17
Jul 29, 2005 11:59 AM
