crazy tick/ rattle
Old Aug 27, 2009 | 01:50 PM
sidewayzz's Avatar
well the problem is it only happens when im in gear and driving so the only way i could record it is if i had a dyno to put it on.
maybe one of these days after class ill try and convince my instructor to let me strap it to the dyno to record it
Old Aug 27, 2009 | 02:23 PM
03lances's Avatar
Not true just jack up the front end and slowly raise the rpms, dont gun it cause there obviously is no resistance.
Old Aug 27, 2009 | 05:09 PM
mcgarvey's Avatar
If you don't have a turbo, you don't spray nitrous, you don't constantly beat the living **** out of the car, and you do change the oil regularly, IT'S NOT A ROD KNOCK. These cars simply don't make enough power to blow themselves up. On the other hand if you've been lax on maintenance or have some aftermarket crap on your engine anything is possible-- but otherwise it's probably just lifter noise or something external like the water pump going bad.
Old Aug 27, 2009 | 05:31 PM
Jehuty's Avatar
Do you have kamikaze headers?
IF this is a yes, that's your problem. My car does the same, in park, you can BARELY hear the ticking, when it's in gear though it sounds like a bee has gone insane.
If it's no...then
Old Aug 28, 2009 | 12:58 AM
03lances's Avatar
I will say my fiances 01 civic has a nice size crack all the way down the stock exhaust manifold and you can hear the valves like nobodies business but there is nothing wrong with them. I have looked and even went and took it to honda and they said the noise was due to the crack as well
Old Aug 29, 2009 | 01:08 PM
sidewayzz's Avatar
no i do not have the kamikaze header.
and im not sure if jacking it up will work but ill try it next time i have someone around to record. ive notice lately that it changes alot with load like when im going up a hill and i dont excellerate and it kinda bogs down without downshifting it gets alot louder but if i hit the gas and make it downshift it gets quieter
im thoroughly stumped on this one
Ian0611
16
Sep 27, 2023 01:42 PM
Hassan
103
Aug 5, 2023 11:37 AM
boostin gsr
Nov 27, 2015 01:34 PM
DFelton
26
Oct 20, 2010 10:28 PM
Turbojunkie
Northwest Region
23
Apr 25, 2006 05:55 PM
