Hi flow cat and factory warranty issues
Old Sep 18, 2009 | 02:09 AM
NERO_NOVA's Avatar
I'm hoping to put together a full exhaust to buy and wanted to know if anyone had issues with high flow cat? Would high flow cats void the warranty iff I took it in to be serviced?
Old Sep 18, 2009 | 02:16 AM
DJ Christian's Avatar
Yes.
Old Sep 18, 2009 | 03:03 AM
NERO_NOVA's Avatar
So even though it wouldnt directly affect the engine in a bad way it would still void the warranty?
Would headers and a catback with the original cat void the warranty as well?
what about the rrm piggyback ecu and timing module?
Old Sep 20, 2009 | 10:10 AM
cRc`22's Avatar
unless ur car malfunctions and u tell them to fix something that they can prove the aftermarket product broke ur warranty is fine.. ive had my car for almost 3 yrs and ive never been to the dealership.. why do ppl go so often?
Old Sep 20, 2009 | 12:35 PM
yitzac1990's Avatar
knowing , they will most likely void ur warranty for not washing your car on a regular basis. if you have a cool dealership where the people are chill, nothing should void your warranty, unless something goes wrong, and the dealer can prove one of your mods caused it. either way though, usually any new exhaust from the cat back WONT void your warranty, because from the cat back is just noise, the cat itself takes care of the emissions thing....however, replacing the stock cat will void your warranty.
Old Sep 20, 2009 | 10:55 PM
JHizzle's Avatar
^ true as said above, but when you mess with the Cat, you give them a lot more ways to try to blame it on the aftermarket cat. so replacing the cat wont directly void your warranty. just like a turbo dosent void your warranty..but you bet your *** if something happens they'll find a way to blame that due to the turbo and what not.
as far as the issues you'll have with the car i cant see too many problems coming from changing the Cat, they cant blame any tranny problems or major things like that..so its all about what you wanna do
also remember when a dealer "voids" your warranty they dont void everything entirely its either your power train warranty, suspension something like that..you can have a turbo on your car and have a problem with your window and they cant refuse to fix your window because you have a aftermarket turbo.
Old Sep 20, 2009 | 11:08 PM
mantosride's Avatar
mitsu can be very tuff, depends on who the warranty rep in your area !
Old Sep 21, 2009 | 02:35 AM
NERO_NOVA's Avatar
Well I figure ill just keep my exhaust in case there is ever an issue. Ill ask whenever I can remember to call my dealer. I'm sorry if this is a dumb question but do they make long tube headers for 4 cyl. And would our lancers ever see one if so?
And tis there only one set of header out for the 2.4?
overdrive1
14
Aug 16, 2015 08:26 PM
chris4b11t
Nov 21, 2013 06:16 AM
twinturbozs
11
Mar 21, 2007 02:31 PM
GunmetalMR
Jun 12, 2006 08:34 PM
cobra2evo
May 15, 2006 05:53 PM
