4B11/4B12 comparison
even though the 4B11T is only semi-closed aluminum, it can still handle 500+ whp. the biggest problems I face when I ask if i want to swap for a 4B11T is:
will all the accessories (PS, AC, alternator, etc.) bolt right up in the same location on the stock block, and,
will a lancer head fit the T block?
if the head doesnt fit, thats another 2k for a full head, maybe more.
sleeving my block would cost about $1200 and I wouldnt have to worry about those problems^^
Did some research on the head and the only difference i can see is that the camshafts and fuel injectors. Maybe little things here and there but yours should bolt up.
on a side note, i see you are from pembroke pines. do you by any chance know of a white 1999 M3 that lives there too? I go to school with him up in daytona, just wondering!
No gain, just will allow you to run higher boost.
Sleeved block is a block that has a layer of steel (stronger than aluminum which the rest of the block is composed of) to better handle high amounts of boost in the block.
Google is your friend!!
http://www.cdpautomachine.com/ecatal...s_sleeves.html
Get a Ralliart, base dyno numbers are really not far off the evo. Get a custom tune and some small mods and your there. I drove an evo x before I bought my ralliart, evos are badass, but not so much a daily driver. The suspension is super stiff and it just seemed more practical to get a RA. Good luck
4B11/4B12 Engines
I would like to replace the 4B11 engine for a 4B12..what major technical and physical difference will i likely encounter? how will the performance in terms of power and speed be affected
Mitsu-noob
May 15, 2014 05:59 PM
xbih87r
Lancer Engine Management / Tuning Forums
Jul 6, 2011 08:14 PM
