replace 4B11 into 4B12 or not?
Old Jan 1, 2012 | 02:13 AM
bsmstar's Avatar
Hi
im new lancer owner..
i got a 2010 gt . which im sure is 4B11 (from VIN) anyway.. a friend of mine.. accept to swab it with his 4B12..
he has 09 GTS CVT with 14000 miles on it
i have 10 GT CVT with 8000 km on it
he say that my engine is better.. i always wanted 2.4L..
so what can i do to ckeck his engine?
should I swab?
is it really necessaey to reprogram ECU ?
he thinks all we should is replace engine and not pistons, etc...
the gt i got has all gts features like 6cd changer, sunroof and fast key...
there isnt turbo kits where i live... so its not an option...
btw, i got 9.5 sec in 0-100 km.. isnt that same as 2.4?
he says mine is 2.4 but again vin says 2.0.. is there a way to confirm its 2.0 or 2.4 ? thanks
Old Jan 1, 2012 | 12:11 PM
gik0geck0's Avatar
http://www.mitsubishicars.com/media/...pdf/11VINs.pdf
VINs don't lie. If the 8th character is a U, you have a 2.0L. If it's a W, you have a 2.4L.
If you do have a 2.0L, and want a 2.4L.. I wouldn't go to the trouble to swap. Someone here has successfully done that swap, but it seems like more trouble than it's worth. You'd have to swap the entire motor, and swap ECUs I believe. The 2.4l and 2.0l should be tuned differently. It would require a lot of work. Do you really want to go through all that for .4 extra liters, good for ~30hp? Neither are that much better for modding. (Though I think there's more support behind the 2.4l) Good luck in whatever you decide.
Old Jan 1, 2012 | 01:21 PM
LiX's Avatar
LiX
Hahahahahaha you don't know what car you bought ?!
Old Jan 1, 2012 | 03:30 PM
BLKGTS's Avatar
I wouldnt do it unless somebody do it for me for free
Old Jan 2, 2012 | 08:34 AM
bsmstar's Avatar
instead i am getting cold air intake... better than goingt through the troubles..
Old Jan 2, 2012 | 08:27 PM
BLKGTS's Avatar
Lol. which one are you getting? Is good to know if you have a 2.4 or 2.0 before buying one
Old Jan 13, 2012 | 12:52 AM
phayder808's Avatar
The basic settlement for this debate is a cash and time factor, if you've got the money and the time (and of course the patience) to do the swap, to each his own, if you don't have the funds for the swap and time for it to be in a shop, it's generally not worth it. Then again I have a 2.4 so I dont really know how badly a 4b11 would want this.
General truths about the swap:
+More power
-less gas mileage
-swap is a headache
Old Jan 18, 2012 | 08:53 AM
Veronica's Avatar
Please forgive a newB question but...
Is not the 4B12 a bored/stroked 4B11? What keeps one from using the 4B12 crank in the 4B11 and getting some displacment and compression bump?
HHmm? (old/old skool hot roddin' FTW! )
Old Jan 19, 2012 | 05:41 AM
M@verik's Avatar
That is correct, however u will need the crank, pistons and conrods from the 4b12 and the cylinder will have to be drilled by 2mm to make room for the slight larger diameter pistons.
Old Jan 23, 2012 | 08:25 AM
nick9g4b1's Avatar
I'd do it.
*also, you should get 280 cams + springs and retainers. an evox thermostat wouldn't hurt either. that set up, easy 265hp+ (with the 4b12 swap/ discussed in other forums) GL
Old Jan 23, 2012 | 08:26 AM
nick9g4b1's Avatar
fawk it!
*do an EVOx swap!
Old Feb 16, 2012 | 06:30 AM
Oksamit's Avatar
Originally Posted by nick9g4b1
I'd do it.
Cams, etc - Made by what company?
Old Sep 17, 2020 | 10:07 AM
Snugglybunnies's Avatar
fawk it!
*do an EVOx swap!
Is an evo swap even doable? I have a 15 Lancer ES, and every performance shop tells me an evo 4B11T is not possible to put in a 4B11 engine bay.
Old Sep 17, 2020 | 01:40 PM
stroopwafel's Avatar
You are replying to a post from 2012. But to answer your question, take a look inside the engine bay of a Ralliart
F22Raptordriver
Lancer Engine Tech
May 25, 2023 07:55 AM
Fredj
Lancer Tranny/Drivetrain Tech
10
Feb 1, 2019 08:25 AM
Igor Nikolic
Apr 20, 2017 03:46 PM
PXAbstraction
Lancer Troubleshooting
Mar 4, 2011 05:53 AM
kmc8302
Lancer Aftermarket Forced Induction Tech
39
Dec 9, 2010 05:06 PM
