Is there any reason i should...
Old Jun 13, 2002 | 12:12 PM
agsmooth84's Avatar
IS there any reason i should pay $279 dollars for the RRM exhaust plus shipping, then pay the money to get it put on somewhere, instead of going to a local import shop, purchasing a performance muffler for around 150 and adding an extra 20 or so to put it on? If theres a good enough reason i will prolly just get the RRM one but right now i dont see one?
Old Jun 13, 2002 | 12:22 PM
Smoktout's Avatar
well, you're really comparing apples to oranges. the RRM muffler is a direct bolt on with a wider pipe but does not replace the cat-back. It only replaces half-way past the cat or something, i can't think of the word right now. anyways, they use wider piping which will be used with their cat-back pipe, and that's really what makes all the difference. if you want to save money, you could always just get a muffler and have Meineke weld it on to ur stock pipes, but for a little more than 300 dollars you could have the muffler you want and a custom cat back pipe made at a muffler shop. that's what i did, i took an A'pexi N1 muffler and did a cat back, total cost me 320, which is probably around the same price when RRM offers the cat back pipe and back piece. hope this helps at least a little bit. good luck
Old Jun 13, 2002 | 01:15 PM
pjal84's Avatar
You may also want to look at the Buschur cat back exhaust and the VRS cat back exhaust as well. Don't limit your options.
Old Jun 13, 2002 | 02:42 PM
Boni's Avatar
I paid $140 for 2.5" mandrel bent piping custom cat back and $40 for my muffler (normal price is $120).
Old Jun 16, 2002 | 04:21 AM
joshkikta's Avatar
I am doing similar to Boni. I purchased a muffler and a high flow cat for about $220 or so and am having it all installed for 160 using 2.5 inch pipe. Now that is a full exhaust, you can probably do it for a lot less if you just go from the resonator back or the second cat and back. All up to you.
Old Jun 16, 2002 | 10:01 AM
b_tapper's Avatar
No reason to buy just an axle back. Really until you get a highflow cat and a header you won't see much of a gain even with a cat back.
Old Jun 16, 2002 | 11:30 PM
joshkikta's Avatar
True. If you really want the power, do a full exhaust. But cat-back is a cheap alternative with some gain and better sound for those who don't want to shell out more or that are worried too much about their warranties. I say go all out and high flow it all.
Old Jun 16, 2002 | 11:41 PM
2wdSQL's Avatar
Just remember to use 2 cats if you want to pass any state with tough emissions laws test.
HobieKopek's Avatar
I tend to agree without exception.
Basically all you'll change is how your car sounds and how the tip looks.
Old Jun 16, 2002 | 11:50 PM
b_tapper's Avatar
1 highflow cat should be all you need.
10thAnv
Apr 27, 2007 12:51 PM
MikeDVB
Apr 18, 2006 06:11 PM
javastan
Jan 10, 2006 01:32 PM
Arithmetic
Apr 6, 2004 03:11 AM
Kelspar01
Dec 25, 2003 11:24 PM
