Octane?
Old Aug 8, 2010 | 02:31 PM
SPARTAN-163's Avatar
Octane?
Ok so i know mistu recommends 87 only. I recently ran my tank down to empty, then filled it with 91. I ran that for a couple weeks, and now my tank is back to full at 87. I honestly can tell a difference in performance, but the real kicker is the difference in MPG. Due to the performance and MPG gain using 91, im strongly considering switching to 91 full time. My question is; am I hurting my engine if I do this? Will the fuel burn too hot for my gaskets, seals and seats? Thanks for any advice or info!
Old Aug 8, 2010 | 02:34 PM
BoostFTW05's Avatar
no not at all. you can run 91 perfectly fine. except im not sure sure but I think they have added a 10% eth. mixture, but you should definately be ok running 91 full time.
Old Aug 8, 2010 | 06:20 PM
T-Pain's Avatar
you should be fine. I ran 91 on my lancer for 2 years before I got my evo and it was fine
Old Aug 9, 2010 | 09:05 AM
I did notice my temp meter registered a lil warmer when i ran 91, so thats where my concern came from. Thanks for the info
Old Aug 17, 2010 | 11:15 AM
CamShaft's Avatar
I run 91 all the time...not only is it a high octane, which doesn't really mean much for our cars, but the fuel is cleaner than a regular 87.
Old Aug 17, 2010 | 11:20 PM
M@verik's Avatar
It is fine. U will gain a little bit of extra torque too.
Old Aug 18, 2010 | 08:06 AM
cfdfireman1's Avatar
the higher the octane the cooler it will burn and more resistant it is to knock meaning ignition temps are higher and it burns slower.
Seifer780
Lancer Engine Tech
May 12, 2016 08:32 AM
Red06Evo
May 31, 2013 04:14 AM
djplay
Sep 30, 2009 07:49 AM
smeghead009
Sep 8, 2006 02:44 PM
davids2004
Sep 1, 2005 05:15 PM
