Overheating!!!!!!
Old Nov 30, 2010 | 07:43 PM
kkrproducts's Avatar
Don't have Jiffy Lube flush your coolant, if the head gasket is indeed bad, there's a good chance it might not be able to handle the pressure the Jiffy Lube flush machine generates. (Over 20 psi)
If I were you, try taking out the thermostat and running the car without it. Might take longer for the car to heat up, but if it overheats, it's something beyond the thermostat.
(I'm not saying drive the car daily without the thermostat, but it's a good test to perform)
Old Dec 1, 2010 | 09:08 AM
HornstarBU's Avatar
Killer suggestion, I hadn't ever thought to do that. Good call, something for me to keep in mind for the future as well.
Old Dec 1, 2010 | 02:57 PM
lil' jeff's Avatar
thought about doin that. im just thinkin its somtething else it just drives to good. so ill pull that tonight and see what happens and ill let yall know. thanx for everything.
Old Dec 28, 2010 | 12:33 PM
BlueKnight32's Avatar
well i have the same problem with my 2004 lancer es (5sp) so does it over heat when your just idling or when your driving?
Old Dec 28, 2010 | 02:45 PM
jakermeister's Avatar
Have you tried changing the radiator cap yet? My dodge dakota did the same thing but I knew it wasn't the radiator or thermostate because I had less than 500 miles on it it turned out the cap wasn't holding pressure.
Old Dec 30, 2010 | 07:42 AM
lil' jeff's Avatar
i just said screw it and yanked the head off had it rebuilt and changed the head gasket. it seems to be doin great now!!! it fried my o2 sensor but hell if thats the only thing i got wrong now im happy. if anyone has any overheating problems wit these cars before spending money on anything just replace the head gasket,it will save time and headaches.if i can do this job then anyone can its not that hard just the timing belt sucks. if u have any questions about the head gasket change holla at me.
Old Jan 2, 2011 | 04:47 PM
mcgarvey's Avatar
Just curious, did you leave the manifolds attached when you pulled the head?
Old Jan 7, 2011 | 07:38 AM
lil' jeff's Avatar
i unbolted them left them in. it was real easy.
Tw3NTy0n3
13
Jun 29, 2016 11:09 AM
EyeDreamt
Outlander Sport
May 27, 2014 02:25 PM
darkside2003
Lancer Troubleshooting
11
Apr 25, 2014 02:00 AM
stiguy
Aug 1, 2011 11:28 AM
Crester
Mitsubishi TC-SST Discussion
Nov 13, 2010 04:53 AM
